Anyone ever gas weld without flame arrestors?
   / Anyone ever gas weld without flame arrestors? #31
Best bet for a part like that is to remachine it after welding it brazing. But if you're careful enough it may be good enough w
Best bet for a part like that is to remachine it after welding it brazing. But if you're careful enough it may be good enough without
Fortunately most of the part is intact. It looks like there are 2 holes for locating dowels which are also intact. It is hard to tell from the picture but it looks like there is an outside diameter made to fit into a bore that would then keep the bearing race inside the part concentric to whatever the part bolts to. If the broken smaller piece is brazed in carefully, and while clamped or bolted to a thick, flat, steel plate or something similar, then I think the chances are good for a successful repair. But yeah, if I was repairing it I would follow all my own advice about how to braze the part and then I would still put it in the lathe, indicate the bearing bore, and machine the part as suggested. But since I own a machine shop this is easy for me.
Eric
   / Anyone ever gas weld without flame arrestors? #32
OK. After looking at the photo and seeing that it is a piece of the front hub I don't believe that I would attempt a fix. Yes, I'm experienced with gas welding and brazing.... and my shop is also equipped with lathe and mill for restoring bearing surfaces. But for this job I would look for a good used or new hub. And here is why:
The FEL on your JD310D can lift nearly 8000 lbs. You might still be OK with that load on a brazed hub....until you tried to turn and/or the front wheels sink in the mud and the rears keep pushing which side-loads the front hub. I'm guessing that may be how it broke in the first place.
You've gotten a lot of really good advice from everyone here about brazing. I guarantee it will come in useful. Torch welding and brazing sure did for me the year I spent doing mechanical work in Central America.
But there is a time and place for everything.
I haven't bought a hub for our 310SG, but I'd expect front hub parts for a 310D to be reasonably priced and available the world over. The 310D is probably the most widely produced backhoe ever made.
I'm seeing too much of the wrong kind of load on that hub. I'd replace it. Save your brazing for another day. But if you do braze it, I'd for sure use a hi-nickel rod, and expect to do some clean up machining when you are done.
Be careful clamping to a plate. Make sure it is a really heavy plate that won't warp, and consider letting one part float for differential heat expansion & cooling.
Consider that when you get done, a lot of the side load is going to be carried by the steel wheel. So pay attention to keeping the wheel mounting surface flat and also to the wheel studs.
Good Luck,
rScotty
Looking at your part I see a good opportunity to make the part come out right. Since there is a large machined surface it is obviously important. It is also perfect for keeping the two pieces in the same plane. If I was doing this repair I would clean all dirt, dust, paint, and oil from the two pieces. Then I would clamp them well to a piece of thick, FLAT steel. Clamping well meaning in this case not just securely clamped to the flat steel but also clamped together, using the broken faces to accurately locate the pieces. Then I would vee out the break about 3/4 of the way through, leaving the last 1/4 to maintain location. when brazing I would make the bead proud of the surface the same amount as the thickness of the 1/4 left as well as double the width of the vee. This is of course only if you have the room. If the brazed assembly is then left to cool so slowly that it takes several hours it will be unlikely for the part to have warped, cracked, or pulled. I think you will do a job you can be proud of and will be confident that the part can be returned to service.
Eric
Hola Eric, there is another outer "cover" to the hub that houses the planetary gears or whatever they're called. It's got another plate with the same bolt pattern. Planning on bolting the whole thing to that to keep it all stable. Preheat, or at least begin it, by throwing the whole thing in the kitchen oven for a while. My wife loves it when I do stuff like that with 40lb backhoe pieces.
My idea has been to bevel it out almost all the way from the top side and a little bit from the bottom side. Then I'll just lay one bead of nickel welding stick in the bottom side (preheated obviously), I'm not worried about just that amount of heat warping the piece. That'll keep everything in place and not allow any braze to leak through to the outer hub cover that I'll be using a guide. Then flip it over and fill with braze.
Welding the patch in like that with one bead will also allow me to work on the holes for the lug nuts before brazing. That's gonna be a pain in the ass, those are big holes. Probably use a combination of drill bits, the cutting torch, and maybe even a dremel to get it just right. Gonna have to practice with the cutting torch a little more first...
Thanks!
Hola! That's what the dude at the machine shop who sold me the piece of metal to make the patch with said. Maybe I can pull it off with just a grinder and a sanding disk but the shop is a kilometer from my house so no biggie if they need to do it. Thanks
   / Anyone ever gas weld without flame arrestors? #35
I'm not exactly clear on just where this is used and therefor the forces that could be on it. But I would opt for a new or used part. If this is from an old machine where parts are not available I would consider making a new one. Once again I don't know if this would be appropriate. But making one on a milling machine from plain steel could be fine.
RScotty and RichN,
Those are valid viewpoints, but we're just gonna bonehead on forward cuz, well, y'know... Just weld that schit up and keep moving, right?
Availability issues for new or used parts are a big problem here and, while totally possible, machining a new one would cost real money. So I'm just going to burn it and see how long it keeps working.
Thanks!
   / Anyone ever gas weld without flame arrestors? #37
Thanks!
I didn't realize until this post that you are gonna weld in a patch. I assume the patch is made from steel. And you are gonna use nickel rod. Some nickel rods are not machinable, which means the weld deposit is really hard. Which also means less ductility. This means the weld bead should be peened as it cools. If this was my part, for my machine, and I was using an oxy-acetylene torch, I would be using regular brass brazing rod. Whether I was brazing together two broken pieces of cast iron or brazing in a steel or cast patch. I would build some sort of "oven" out of fire brick or at least red brick. I would make sure that after brazing I could close the top of the oven with more brick. If no brick available I would use dry sand. I would pre-heat the **** out of it. Get it to 700 or 800 degrees. At least. Hotter wouldn't hurt. This would not only make brazing easier but would also help greatly with stress relieving as the part cooled. Once done with the brazing I would cover well enough to make sure it would take at least 6 hours to cool. I can't stress enough how important slow cooling is for a successful repair. Did I say slow cooling is important? Oh yeah, I would also take that bearing race out.
Eric
Thanks Eric, I'd been wondering about the bearing race
   / Anyone ever gas weld without flame arrestors? #39
I know you are in a tough situation because it is not easy to get replacement parts. All the more reason to carefully remove that race.
You do not want to warp the bore when you braze in a new piece. Because the bore for the race had to be accurate the part must have been stress relieved before machining. Since this basically involved heating the part at a controlled rate and then cooling it the same it is unlikely that you heating the part will change it. But brazing in a steel piece may. So you want to make sure that the brazing material will give before the cast iron and help retain the original part shape. You don't want the patch to pull the part out of shape.
Cast iron has a yield strength that ranges from about 10,000 PSI to 60,000 PSI. Brass, which is what typical brazing rod is, has a yield strength from about 18,000 PSI, to about 45,000 PSI. Good cast iron is usually going to be near the high end, say 45,000 PSI yield. I'm thinking your part was probably made with pretty high quality cast iron. Brass brazing rod is probably closer to the middle as far as yield strength but may be closer to the top, but still probably has a lower yield strength than you cast iron part. This is good. Allowed to cool slowly a brass brazed joint will probably move and stretch instead of the cast iron.
Since you are putting in a patch I would not worry about brazing at all from the machined flat side. I would make one side of the patch as flat as possible. This side of course gets clamped to whatever you clamp the part to be repaired to. Then grind it to fit you part. Vee the patch and part almost to the flat sides, getting as close as maybe 1/16 inch. Don't go all the way. The part does not need to be brazed 100% of the way through. Just make sure your braze bead is proud of the surface that fits the air the same amount. At least.
I would also suggest looking on YouTube for similar repairs, I'm sure there are a few videos done by folks who know what they are doing that will give you some good hints.
Please show us some pictures of your repair.
Eric
I gotta get a little more practice with the torch before I start messing with the hub, but I feel like it's all coming along nicely. Thanks for all the advice, I'll definitely be putting pictures up soon.
Ford Tractor (A57148)
2013 John Deere 824K Wheel Loader (A56438)
2013 John Deere...
2020 Case CX80C Excavator (A59814)
2020 Case CX80C...
(1) HD 20ft Free Standing Corral Panel with Feed Bunk (A57453)
(1) HD 20ft Free...
UNUSED CFG INDUSTRIAL H12R EXCAVATOR (A58375)
UNUSED CFG...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
