Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #19,212
Everyone works out a system they like best based on their equipment and wood. My splitter is a 22 ton Husky and I doubt it would push a 4-way wedge reliably so I have to make multiple splits on the same round. For me it is a lot easier to have the wedge move and the round stationary so that on multiple splits I can stand in one place and not have to keep pulling back the round to make the next split. For big rounds I put the splitter vertical and break the rounds down to handling size. Working off my carry-all is convenient. Then I go horizontal using the loader as a lift table as I do on normal sized rounds. Again stand in one place, grab a round and make as many splits as it takes throwing the splits into a trailer or a rough pile for air drying.
gg
Aging is a great incentive to work smarter. I too find the horizontal/vertical moving wedge options on a splitter fits our needs better. Maybe because it’s all I had. 30+ year old Northern Hydraulic splitter only replacing motor and hoses.
   / Tractors and wood! Show your pics #19,213
A lot safer too !
gg
Exactly. That was my main reason for cradling the cutoffs. Those are decent sized and I was standing on a branch. The main trunk can shake when the cut completes and the last thing I wanted is to be under the cutoff when it came down.
   / Tractors and wood! Show your pics #19,214
I may have a similar one. Horizontal $750 brand-new in 1998. It's replacement is now more like $4500 because Northern no longer makes a simple horizontal splitter and i don't know if I'll live that long to justify that expenditure.
   / Tractors and wood! Show your pics #19,215
Yesterday moved nearly 5 cords of firewood into the garage. I have nearly 3 more cords in reserve. And 20 logger cords that need processing. It can be a long cold winter and we will be covered.
Also had my two 500 gal propane tanks filled. I have a contract price of $1.59, which is 33% higher than last year. But there is an escape clause in the contract that nullifies the contract if Line 5 is shut down....so wanted to get them topped up. Primary need for propane would be a long power outage.
   / Tractors and wood! Show your pics #19,216
And I thought my 15 cords (ahead) were a lot. 🍪
   / Tractors and wood! Show your pics #19,217
Seems wood would be better for a power outage??
   / Tractors and wood! Show your pics #19,219
I've been over "by you" to curl in Lewiston....
Glad I heat with wood, that's for sure.
   / Tractors and wood! Show your pics #19,220
gg
We do all adapt to the equipment available and our own personal preferences. I'll use my loader bucket or the hydraulic lift as a staging table, but for me, throwing the wood causes more problems than pulling it back to resplit. After a couple of bouts with something like tennis elbow from grabbing and throwing logs, I had to shift the way I worked. Tha one hand backhanded toss was killing me. So I went looking for a splitter that would push the logs of the end, and at the right height to feed into directly in to my trailer. Once I found a good one, I sold my old horizontal/vertical splitter. I don't really have to move to pull larger logs back to resplit. The work table on the splitter catches them. For easily manageable sizes, I move maybe a half step to reach them and pull them back. For larger ones, it might be a full step. For me, that far beats picking the split pieces up and throwing them in the trailer.
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
UNUSED EINGP MSC2020F 20' X 20' ALL-STEEL CARPORT (A54757)
UNUSED EINGP...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
2014 Ford F-150 Ext. Cab Pickup Truck (A52377)
2014 Ford F-150...
