Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #19,212
Everyone works out a system they like best based on their equipment and wood. My splitter is a 22 ton Husky and I doubt it would push a 4-way wedge reliably so I have to make multiple splits on the same round. For me it is a lot easier to have the wedge move and the round stationary so that on multiple splits I can stand in one place and not have to keep pulling back the round to make the next split. For big rounds I put the splitter vertical and break the rounds down to handling size. Working off my carry-all is convenient. Then I go horizontal using the loader as a lift table as I do on normal sized rounds. Again stand in one place, grab a round and make as many splits as it takes throwing the splits into a trailer or a rough pile for air drying.
gg
Aging is a great incentive to work smarter. I too find the horizontal/vertical moving wedge options on a splitter fits our needs better. Maybe because it’s all I had. 30+ year old Northern Hydraulic splitter only replacing motor and hoses.
   / Tractors and wood! Show your pics #19,213
A lot safer too !
gg
Exactly. That was my main reason for cradling the cutoffs. Those are decent sized and I was standing on a branch. The main trunk can shake when the cut completes and the last thing I wanted is to be under the cutoff when it came down.
   / Tractors and wood! Show your pics #19,214
I may have a similar one. Horizontal $750 brand-new in 1998. It's replacement is now more like $4500 because Northern no longer makes a simple horizontal splitter and i don't know if I'll live that long to justify that expenditure.
   / Tractors and wood! Show your pics #19,215
Yesterday moved nearly 5 cords of firewood into the garage. I have nearly 3 more cords in reserve. And 20 logger cords that need processing. It can be a long cold winter and we will be covered.
Also had my two 500 gal propane tanks filled. I have a contract price of $1.59, which is 33% higher than last year. But there is an escape clause in the contract that nullifies the contract if Line 5 is shut down....so wanted to get them topped up. Primary need for propane would be a long power outage.
   / Tractors and wood! Show your pics #19,216
And I thought my 15 cords (ahead) were a lot. 🍪
   / Tractors and wood! Show your pics #19,217
Seems wood would be better for a power outage??
   / Tractors and wood! Show your pics #19,219
I've been over "by you" to curl in Lewiston....
Glad I heat with wood, that's for sure.
   / Tractors and wood! Show your pics #19,220
gg
We do all adapt to the equipment available and our own personal preferences. I'll use my loader bucket or the hydraulic lift as a staging table, but for me, throwing the wood causes more problems than pulling it back to resplit. After a couple of bouts with something like tennis elbow from grabbing and throwing logs, I had to shift the way I worked. Tha one hand backhanded toss was killing me. So I went looking for a splitter that would push the logs of the end, and at the right height to feed into directly in to my trailer. Once I found a good one, I sold my old horizontal/vertical splitter. I don't really have to move to pull larger logs back to resplit. The work table on the splitter catches them. For easily manageable sizes, I move maybe a half step to reach them and pull them back. For larger ones, it might be a full step. For me, that far beats picking the split pieces up and throwing them in the trailer.
(INOP) 2005 BRODERSON IC80-3G 9 TON ROUGH TERRAIN CRANE (A51406)
(INOP) 2005...
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
Fiberglass Cow Statue (A55218)
Fiberglass Cow...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55218)
Kubota BX2680...
