Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #19,422
Thanks, although I wish it had a dump. Working on getting next years wood even though this drys out pretty quick.
   / Tractors and wood! Show your pics #19,423
I picked this up in 2019, gambled on spending the money since it didn't run, have had to do everything from have injectors & pump rebuilt, rewire pretty much every light, change all fluids and filters, paint, remove all the PTO cables and re-lube, put 4 gallons of hydraulic fluid in it. But now she's a strong runner that dumps. Well it dumps when empty, hesitant to load it and then find out it won't dump a load, then I'd have to unload by hand....
When I bought it.
As it looks now.
   / Tractors and wood! Show your pics #19,425
Nice truck. Seems like every truck I looked at needed a little TLC. Im still fixing and changing things on mine. Should have got one a long time ago.
What motor is does it have.
   / Tractors and wood! Show your pics #19,426
This one's got a DT-366, not a huge power plant, but its all mechanical therefore I took the chance. If it had any electronics, I would have walked away.
   / Tractors and wood! Show your pics #19,427
Agree 100% on mechanical. Mine has the 5.9 cummins
   / Tractors and wood! Show your pics #19,428
From what I heard, the motors are about the same size. (in Liters) I 've been looking for a Ram 2500 with the 5.9 cummins, good engine!
   / Tractors and wood! Show your pics #19,429
Depends on what series of the B series 5.9, some of them had a lot of issues.
   / Tractors and wood! Show your pics #19,430
Yes, was it the series 53 or 57 block had the weaker casting? And then the alignment pin issue in the water pump, but all in all the 12v was a good quality all mechanical motor.
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2013 CAT 246C (A47477)
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
(41) T-POSTS W/ (20) ROLLS OF BARBED WIRE (A54757)
(41) T-POSTS W/...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
