Added an electrical actuator to my snow blower chute deflector.
   / Added an electrical actuator to my snow blower chute deflector. #1
SylvainG
South West, Qc
Kioti LK30
Not much but I added this electric actuator I got from Amazon to adjust the chute's deflector. No more leaving the tractor to adjust it :) Used a scrap piece of metal (1/8" thick) to extend the actuator so it reaches the holes of the original deflector's adjustment rod. Switch to control the actuator is also from Amazon.
   / Added an electrical actuator to my snow blower chute deflector. #3
Nice mod! Good point about flipping it around.
pretty similar to my install. I have read, you want the arm down and the motor on top, due to water intrusion. Good luck!
Good idea. The actuator is IP54 which should protect it from rain but adding another layer of protection doesn't hurt.
Well, turns out that actuator is not as water resistant as it was said to be, even pointing upside down :mad: It wouldn't move until I thaw it inside. I'll see if I covering it from the element is enough to keep it moving, otherwise I guess I'll have to disconnect it and bring it inside after each use.
   / Added an electrical actuator to my snow blower chute deflector. #6
Could it still be wet inside? My guess would be that once moisture gets in there it takes quite some time to dry out. Maybe remove it, take it inside and lay it on a hot air register in the house till the next time you need to blow snow. Just my 2 cents. 😏
   / Added an electrical actuator to my snow blower chute deflector. #7
I would try to fashion some sort of bellows for the actuator rod so water can run down the rod into the housing. Maybe even give it a coat of some kind of spray sealant to seal up the gearbox end.
That's what I did. It thawed and it's working again. I'm going to leave it inside fully extended until it's time to use it again.
It's pointing down (i.e the cylinder is higher than the rod). I think only humidity can get in but who knows. I'll leave it inside for now.
   / Added an electrical actuator to my snow blower chute deflector. #10
I'm toying with the idea of copying your solution for adjusting the top chute from the operators seat. Does your actuator still freeze up after you blow out your drive? I use an electric window motor from a parts vehicle I had handy to swing the chute to either side - made necessary when I built a snowcab for my machine. The crank system would have been a major inconvenience. If I could aim the top chute down more when shooting against wind or driving into the wind, maybe I could avoid buildup of snow on the windshield. I don't have a wiper on there.
   / Added an electrical actuator to my snow blower chute deflector. #11
   / Added an electrical actuator to my snow blower chute deflector. #12
I did the same mod to a snowblower I owned previously.
Never had an issue with water intrusion! Only complaint was the actuator I used was slow.
Snowblower - Linear Actuator on Snowblower
The one I have is also slow. I tried it for various tasks and found it to be too slow to be of use at any of them. I'm hoping it won't matter as much on the deflector. Is there even any actuator that isn't slow?
Didn't have enough snow to use the snowblower so far. It either melted before I could blow it or not enough so I used the ATV/plow. It might have been the temperature fluctuations between above/below freezing point that froze the mechanism. I only noticed it when I tried to move it to test how it would behave. It's pretty cold now so I'll see once we get a real snow storm.
   / Added an electrical actuator to my snow blower chute deflector. #14
What you have going on sounds like our winter last year. I only got to use the blower twice all winter and one of those times it was mostly to test out the mods I'd done on it. This winter I have lost count of the times I've been on it. And it's because I have used it quite a lot that I find out what could be improved. If the electric deflector chute is not the answer I'll be putting a wiper on the windshield and maybe the side windows as well. The blowback when I'm working against wind keeps sticking to the windshield, side windows and the mirrors. Hopefully when that happens I can shoot the snow up and over the snowcab.
Well, my actuator is dead. I'll need to get another one. Hopefully it's a fluke and the new one won't have that issue. I'll make sure to install it with its rod pointing down this time. I opened it and just the motor itself has trouble spinning. I don't see any water infiltration but had it installed for a few weeks when it was raining last fall with the rod pointing up.
   / Added an electrical actuator to my snow blower chute deflector. #16
i Wonder, if you can install a double lip grease seal on the shaft taped to the housing or something, ( i would 3d print something), i would be pretty confident that would keep over 90% of the water out.
I have no concern with mine, im not using mine in the wet, odd the motor is having a hard time turning. gl on the next one
   / Added an electrical actuator to my snow blower chute deflector. #17
Good possibility some windings overheated when you tried to run it when frozen. Those tiny motors have even tinier (delicate) wire in the windings and do not tolerate sitting and humming for long.:mad: I'll make sure to keep it in mind when I modify my blower with a copy of your setup.
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
2400 (A60432)
2400 (A60432)
2015 Ford Explorer AWD SUV (A59231)
2015 Ford Explorer...
S/A Yard Dog Truck (A59230)
S/A Yard Dog Truck...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A60429)
2014 CATERPILLAR...
2014 Audi Q7 AWD SUV (A59231)
2014 Audi Q7 AWD...
