Kubota 1996 M5400 2WD Front Tire Recommendation
   / Kubota 1996 M5400 2WD Front Tire Recommendation
There’s a couple tire shops around and I’ll be cking w them. I try to first use all the local family outfits. I think it’s worth it to pay a little more and use them.
I’m going to the ranch tomorrow and determine if the current tires I have are 8 or 10 ply. I have a pretty heavy duty frt end loader so I’ll definitely go w 10 ply. I’ll take some pics tomorrow & post them.
Wishing everyone a safe, healthy & prosperous new year !!
   / Kubota 1996 M5400 2WD Front Tire Recommendation #12
A high quality 8 ply domestic tire will outperform a 10 ply Chinese tire 9 times out of 10.
   / Kubota 1996 M5400 2WD Front Tire Recommendation #13
Hello to all & HNY !
The original Goodyear (GY) 2WD 7.5 - 16 ribbed tires are close to their end. I have tubes in both of them now.
Looking for recommendations on replacing both front tires. Is the quality of 2022 GY still there, or is there a better brand available? Thank you.
PS - I’ve kept the tractor in a nice shed when not being used so no UV except when using it
Hope everyone has a safe & prosperous new yr / tstex
Goodyear no longer makes their own ag tires, they sold the division to Titan who makes and sells the Goodyear-branded tires. The ones I've been around that have been made in the last 10 years have been fine. I've not had any issues with any of the larger makers (Firestone, Titan/Goodyear, Galaxy/Primex, Carlisle). I haven't seen newer 7.50-16 F2 tires available in 10 ply though, they are 6 or 8 ply. Most of the tractors this size specify a 6 ply 7.50-16 tire, but you would need to check your manual as Kubota doesn't post them online. Heavier is fine though.
   / Kubota 1996 M5400 2WD Front Tire Recommendation #14
I got a pair of used 22ply aircraft tires for a 2wd Ford 4500 backhoe. Worked well for over 20 years. Easily handled heavy loader work. At the time they cost less than standard rib non-flotation tire.
   / Kubota 1996 M5400 2WD Front Tire Recommendation #15
I don't think the local Kubota dealer sells tires. There are so many tire shops in this area. For tractors I prefer Goodyear or Titan. I have a Les Schwab tire dealership locally. I buy all my tires from them.
   / Kubota 1996 M5400 2WD Front Tire Recommendation #16
We used Goodyear light aircraft tires on the front of our 33 hp do-everything Yanmar because that was the best fit to keep the 4wd ratio correct with oversize rears. Lots of plies, good sidewall rigidity with the loader, but still gave a better ride than a tractor tire. We ran it in hard rocky ground. Tread is universal type insteadof ribbed, and the tire shape was sort of fat instead of skinny like a ribbed front. The tread looked more like an all-weather automotive tread. Cost was about the same as a standard tractor tire, maybe less.
rScotty
Thanks for everyone's replies...I have not been able to make it out to the country since my prior post, but will be going out in the next day or two and will take pics...Happy New Yr
Well,
Here’s a pic of the front tire and it’s a 7.5-16 Firestone but I was surprised it was a 6 ply and not at least an 8-10 ply. Therefore, if I went w an 8-ply bc of the front end loader, I should be good, yes?
Thanks for your feedback
Rick,
thanks. Is an F2 8 ply or other?
What specs need to be specified for the ribs indicated in the pic along w 7.5-16 8-ply? Thanks again
New/Unused Electric Golf Cart (A57453)
New/Unused...
2016 GENIE S-65 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE S-65...
PALADIN INDUSTRIAL SCREENER (A58216)
PALADIN INDUSTRIAL...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
2021 Kubota SVL75-2 (A57148)
2021 Kubota...
