Building The Outdoor Stairs
   / Building The Outdoor Stairs #41
great job on the foundation work and on the forms way too often I see people under estimating the push of concrete ... and for the water content look like you will be just fine bit looks good but yes for mixing you basically need the ''minimum'' amount of water possible to be able to mix it and for the curing time it need to be as humid as possible you don't want it to generate too much heat so cover it from the sun and putting water on it during the curing help (curing time is up to 40 days) ... so usually after a poor start to cure I will hose it down to cool it off ... our concrete curing chamber at school was at about 15 to 17 degrees Celsius and the mist from the sprinkles would start after a few hours after being place in it.
   / Building The Outdoor Stairs #42
I always keep my concrete covered in plastic as long as my customer or I can tolerate.
Well it's a very interesting feature of that concrete!
Too much water in the mixture proportion is bad, but plentiful watering during curing time is recommended!
I assume the covering a concrete is desirable even in summer to protect it from sun heating and too fast curing. But a plastic cover also traps moisture like in a greenhouse. In my case, I wanted the concrete not to rush to dry fast, but at the same time I wanted it to cure and to dry until frost will come along, that appeared 2 months after concreting. Therefore, it was covered the top of a surface only. Wind and changes in ambient temperature as well as humidity can freely circulate underneath the cover.
   / Building The Outdoor Stairs #44
Something to consider is that the advice you are getting from everyone is for flat work. While it's true that extra water will cause the concrete to crack and it will not be as strong, it is also true that what happens on flat work is not the same as what happens on monolithic pours like your stairs.
Ideally, less water would have given you more strength. But in all reality, the stairs are not going to support anything heavier then people carrying furniture. Never will there be more then half a ton of on them, compared to several tons of weight on a flat slab.
It's nice that everyone took the time to suggest other methods to accomplish what you have done, but from what I saw in your pictures, and all of the rebar that you used, there is no doubt in my mind that you have created a set of stairs that is more then strong enough for the task, that will last hundreds of years.
I am indescribably grateful to all the TBN members who have contributed to this thread. I thought I’d just share some information about what I'm doing. But the events turned out so, that I got a lot of fantastic advices on an issue. No one was obliged to respond, but yes, everyone is doing it in good faith and so, using their and their families’ precious time. And that’s invaluable.
I hope everything will be fine and this thread will be extended with some more interesting things.
Thank you all again and again. (y)🤝
   / Building The Outdoor Stairs #46
as a adolescents me and my dad made some concrete footings and it was a strong mix we went generous with the cement mixture, 10 - 15 years later the edge of the concrete is all flaking off and I could take a hammer and probably work through it, after going to school I realize the mistake. first one the mixture was too wet, we could just dump the concrete from the mixer in the wheel barrel it will all run off. Second mistake it dried up too quickly. (south side is worse the north side) I am tempted to disagree with your statement, for the base sure I agree it doesn't need to be super strong but for the stairs surface you want some strength you don't what that concrete to wear off from the footsteps, snow removal and salt over the years. Foot steps over time wear off lime stone (hardness 2-4) so it will wear off poorly mix concrete ( quality Polish concrete hardness (6 - 7)). But I do understand your point it not a bearing structure, with that being said id like to point out concrete itself take care of the compression and rebar take care of the tension. The rebar doesn't help the supporting any weight.
Thank you for sharing your experience.
In any case, like I've stated earlier, I planned to putty the whole surface of the stairs with a Finnish product called Weber Outdoor Repair. It's a really good one, I used that already.
Here's a video just in Danish.
The cement I'm using called ROCKET CEMENT M-600, made in Sweden not in Poland. We have a choice, because there is a local cement factory. But I chose that one.
   / Building The Outdoor Stairs #48
first time I see this product thanks for sharing.
I think there are lots of such products or even better ones made in N. American states. It was just my thought you could see this one in a market just among many others as a competitor.
   / Building The Outdoor Stairs #50
Beautiful job on forming and reinforcing your stairs. Hope everything turns out good.
Here are some things to consider when you are ready to pour the upcoming supporting deck beam.
1) Be sure to include aggregate (different sizes is best).
2) Mix as stiff (less water) as you can (add water a cup at a time near the end of the mixing process). The optimum ratio is 0.4/1.0 water/cement
3) The wetter you can keep it during the curing the stronger it will be. This is a cement hydration process, it is not "drying".
4) There is a thing such as to much cement in a batch and will actually make the finished concrete weaker.
5) Typically, it is expected that a concrete mix will reach 50% of its design strength in 3 days, 75% in 7 days, and 98+% at 28 days.
I know you were trying to mix thin to get the concrete to flow in the forms but a "Hand Held Concrete Electric Vibrator" such as this one on Amazon
(Amazon.com)
this is just an example because I don't know what your electrical requirements are.
This vibrator will make a very stiff concrete mix flow very good and fill your forms without a lot of air pockets.
Good luck
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
