James Webb Space Telescope begins historic mission
   / James Webb Space Telescope begins historic mission #111
She's at a crawl of 477 mph. Two days before L2 Orbit Insertion. Sounds like there's been no hiccups so far. I believe there are 18 mirrors. Each have 6 little motors to adjust them into focus. All performed.
That's 108 little motors and no failures. Show me one thing you can buy 108 of without at least one being bad!!!! :cool:
   / James Webb Space Telescope begins historic mission #112
They must be actuators. That is an electric motor, connected to gearbox turning a screw of sorts. I use them on snow implements and they do well with that. (y)
   / James Webb Space Telescope begins historic mission #113
I assume they are. I watched a video about it. The mirrors are made of a flexible material coated with Gold. The motors/actuators push/pull on the mirror to tilt it as well as convex/concave it for perfect, sharp reflection. I believe they said it takes 10 days to do all of the adjustments. Gold was used because it retains it's sheen even when distorted. I believe it was a golf ball size piece of Gold on each mirror.
Ruffdog can confirm all this. His depth of technical understanding far exceeds mine. :cool:
   / James Webb Space Telescope begins historic mission #114
It is amazing how they can make all those adjustments, with accuracy, in those conditions, from this far away. Gold is fairly durable AND keeps a sheen better than anything. All they have to do now is use the little boosters to position it perfectly in L2 orbit. (y)
   / James Webb Space Telescope begins historic mission #115
I kid you not. I've had people tell me. "those can't work, I need more power, get contaminated, etc etc"
   / James Webb Space Telescope begins historic mission #116
Actuators are a tidy way to move things. Just have to remember their limitations.
   / James Webb Space Telescope begins historic mission #119
The gold coating on the mirrors is about 100 nanometers thick, about 600 atoms thick, and was applied using a vacuum deposition process in a large vacuum chamber.
A total of 48 grams, 1.7 ounces, was use to coat the mirrors.
   / James Webb Space Telescope begins historic mission #120
Wonder where I got that golf ball size piece of Gold. Your description wouldn't be that big would it? Pretty amazing stuff.
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2017 FREIGHTLINER CASCADIA SLEEPER (A53426)
2017 FREIGHTLINER...
2017 Bobcat S70 Compact Wheel Loader Skid Steer (A51691)
2017 Bobcat S70...
(APPROX 34) 1 1/2" X 10" X 38" CHANNEL IRON (A51247)
(APPROX 34) 1 1/2"...
