Kubota RTV Cabin Blower not Working
   / Kubota RTV Cabin Blower not Working
If it has the relay, post it and I'll give you the Digikey cross reference number. My dealer wanted 70 bucks for the relay. Crossed it on Digikey for 4 bucks. Bought 2, just in case. 70 is highway robbery.
Will do. In the meantime I’ll look at the aftermarket kits and get familiar with the components typically used.
Did some troubleshooting and it looks like an aftermarket heater. Only had ~7-8vdc at the switch. Chased the power wire back to an inline fuse near the battery. Has to spray with WD40 to loosen up the mud and corrosion I found inside. I’ll plan to just replace the inline fuse and reconnect to the battery. Any idea what size fuse to use. This is the blower motor:
   / Kubota RTV Cabin Blower not Working #13
Look at the wire size. Circuit fuses are designed to protect the wiring and not the device.
   / Kubota RTV Cabin Blower not Working #14
Check the size of the inline fuse, once you remove it, and use the same size, in the new fuse holder.
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
LMC LOT NUMBER 254 (A53084)
LMC LOT NUMBER 254...
Ford Super Duty 8ft. Truck Bed (A51692)
Ford Super Duty...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
