the old grind
Super Member
- Joined
- Jul 21, 2012
- Messages
- 5,083
- Location
- Mid-Michigan
- Tractor
- NH T-1520 HST, NH TC33DA HST, Case DX26 HST, .Terramite T5C, . NH L785
gsg, From Speer #14, for 125/130g and likely ok with other typical 'cup and core' pills of the same weight and with CCI 200s:
IMR 4198 29g max, start at 25g and work up. Min velocity 1969, max 2185 in 22" barrel. MEs from 1075 to 1320 accordingly. Expect BCs to be just shy of .200, but IMO shots from 150-200 yds would be reasonable performers.
I have access to hundreds of .308 loads of all bullet weights, many exclusive to online memberships, but tested. What matters is the bullet weight, primer, and powder you have on hand. Name 'em and I can see what else is out there.
btw, Somewhere in between the above and typical 'factories' there are many recipes whose velocity and ME fall in between with starting loads. Get your COAL right for you chamber with each bullet, and the rest is easy.
"What have we got so far?" ("Ajax Liquor Store", Hudson & Landry)
