PowerStroke ICP sensor to monitor hydraulic pressure?
   / PowerStroke ICP sensor to monitor hydraulic pressure? #1
jigs_n_fixtures
Salmon, Idaho
TYM T233 & T293 CAB
I was looking on ebay for an electronic oil temperature gauge to monitor the hydraulic temperature. Found a manufacturer who has a gauge to monitor the fuel pressure on a Ford 7.3 power stroke using the factory ICP sensor. The gauge has a range of 0 to 4000-psi. the tractor hydraulics relief pressure is 2750-psi. So, I’m well within the pressure range of the gauge and sensor.
Does anyone know of a reason I cant just buy the sensor, and the gauge, and use them to monitor hydraulic pressure. I know I’ll have to figure out where to tap in to the hydraulics, but that is the minor part.
   / PowerStroke ICP sensor to monitor hydraulic pressure? #2
sounds like it would work but I find hydraulic temp is not a problem. Most tractors have a large sump capacity that acts as a heat sink. especially in winter. I can blow snow for an hour at pto rpm and the hydraulic oil doesn't get past 105 degrees F
you might get into a issue with the pressure spikes generated through use. My tractor system is 2650 psi but the 3pt safety valve is set somewhere around 5000psi I like to know system pressures as a diagnostic tool, but I don't think there is a need to see the pressures all the time.
   / PowerStroke ICP sensor to monitor hydraulic pressure? #3
Yeah, you would more likely overheat the engine before the hydro, which is why the manufacturer provides a gauge for engine temp. As you said, the entire case is acting as a heat sync and there should be hydro cooler coil in the fan stack as well.
   / PowerStroke ICP sensor to monitor hydraulic pressure? #4
Why a digital gauge and worry about wiring and power. Whats wrong with a simple mechanical gauge for pressure?
There isn’t a convenient place to mount gauges on my subcompact.
I‘m thinking of adding a three gauge cluster with a volt meter, oil temperature gauge, and the pressure gauge. I would mount them on the front of the canopy, because that is where they can be mounted and easily visible.
I’m looking at electrical/digital, because the logistics of running a set of wires, is lotus easier than the tubing required for machanical gauges, And frankly, running a 2700-psi line up around my head doesn’t seem like a great idea.
2005 Jeep Wrangler 4X4 SUV (A55758)
2005 Jeep Wrangler...
Bigfoot Metal Stand Up Sign (A55758)
Bigfoot Metal...
7022 (A50322)
7022 (A50322)
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55788)
2021 Chevrolet...
2015 Freightliner M2 Chipper bucket Truck (A52377)
2015 Freightliner...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
