BX1880 3ph slow to lift
   / BX1880 3ph slow to lift
So, like I said they isolated the problem to the control valve for the 3ph. My dealer told me he had a hard time swallowing $700+ for a new valve without knowing WHY that one wasn't working properly. He disassembled it (the fella I'm speaking of is the one who owns the dealership. He tore my tractor down himself, I love that place) and found that the spring for the check valve was inserted backwards. I wish I had the picture, but basically the spring had a conical shape, and the "big end" was turned toward the steel ball. So the ball was inside the spring. It didn't take much flow to push the ball sealing the opening and closing the check valve. He turned the spring around so the small end was facing the ball and VIOLA! Works perfectly.
   / BX1880 3ph slow to lift #12
Thanks for letting us know, I wonder if any other dealer would have found that?
Best,
ed
I suspect most would have just replaced the valve, but I don't know. Fixed is fixed as far as I'm concerned, but I'm sure disassembling this one and fixing it saved me some time waiting on parts to ship!
2019 CUMMINS CM20-1 PORTABLE SKID GENERATOR (A55745)
2019 CUMMINS...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
New/Unused 200lbs Cast Iron Anvil (A54865)
New/Unused 200lbs...
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
2011 TROXELL 150BBL VACUUM TRAILER (A55745)
2011 TROXELL...
