MF30 electrical problem
   / MF30 electrical problem #1
ndmarks
dublin, ca
mf30
I have an electrical problem with my MF30. All of a sudden neither my Ampmeter nor the Fuel Gauge are working. The alternator seems to be putting out voltage. Any ideas? Nick Marks, Dublin, Ca
Check to see if you have a separate instrument fuse.
Actually my symptom description was wrong. The ampmeter is actually working as the needle goes negative when I hit the starter. It actually acts like the alternator died. The fuel gauge still doesn't work. I am trying to get a copy of the electrical diagram. I have the full service manual but somehow I misplaced that page from the electrical section. Thanks for the reply. Nick Marks, Dublin, Ca
   / MF30 electrical problem #4
On many Massey tractors of that era had externally regulated Delco alternators. The fuel gauge was powered from pin 4 on the regulator. If the system isn't charging there is no power to pin 4 (so no fuel gauge operation).
Thank You so much for the information. When I get back to the ranch I'll check that. Nick Marks, Dublin, Ca
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2018 KENWORTH T680...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
KBH Tank Trailer (A56438)
KBH Tank Trailer...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
