Please help! TL100 won’t move after flat battery
/ Please help! TL100 won’t move after flat battery #1
Joshmcmillan
New Holland TL100, TS100 x2, T5050, Fiat 580DT, 540
Hello! Appreciate any assistance or ideas.
We have a New Holland Tl100 with the 2 speed power shift and shuttle.
Recently it sat for a couple of weeks, and jump started fine for use. It started under its own power and was used later the same day.
A few days later, battery was flat again so I replaced it. Now the tractor won’t move.
It starts fine, all other hydraulics work. No fault codes or lights on dash. Does not display the rabbit/turtle light as it would usually. Dealership came out and there computer wouldn’t plug into it so they left.
I have checked wiring to solenoids, checked resistance on clutch sensor, shuttle lever works etc…..
Is there anything else I can try?? Once I had to calibrate the transmission on our TS100 after changing battery - could this just need that if I called a dealership requiring 8 hours travel that has the right tooling? Or if it needed that should it be displaying the fault light on the dash?
/ Please help! TL100 won’t move after flat battery #2
I'm no mechanic, but I wouldn't think a dead battery would cause all of that.
Maybe when jumping it, a fuse for the safety switches blew.
my suggestion would be to check all fuses; might be more than one fuse box. Manual should list them. Surprised the dealer did not do that when they came out.
Thanks for the reply!
I’ve checked all the fuses with a multimeter.
The manual isn’t much help as it just says to refer to error codes, but I’m not getting any.
/ Please help! TL100 won’t move after flat battery #4
Does the PTO work?
/ Please help! TL100 won’t move after flat battery #5
I would be interested to know how the matter was resolved?
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
New Holland T2420 (A53317)
New Holland T2420...
UNUSED ZJG ZJ-08 MINI DIGGER (A60430)
UNUSED ZJG ZJ-08...
2019 CATERPILLAR 420F2 IT BACKHOE (A60429)
2019 CATERPILLAR...
2002 Ford Econoline E-250 Cargo Van (A59230)
2002 Ford...
