***UPDATE*** Mice ate my light wiring, ques on the wire connectors
   / ***UPDATE*** Mice ate my light wiring, ques on the wire connectors #1
tstex
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
I found out why my lights would not come on (pic 1)
Are the white connectors reusable? (Pic 2&3) If so, what’s the process of removing old and installing new wires?
if not, does anyone have a source?
thank you in advance
   / ***UPDATE*** Mice ate my light wiring, ques on the wire connectors #2
You should be able to release the metal portion (terminal) of fittings (usually have spring lock of sorts that a straight slim object can depress and terminal should come out and you can open up crimps and put on new wires....
   / ***UPDATE*** Mice ate my light wiring, ques on the wire connectors #4
I use dental picks for pushing into those things to release the little spring flats
👍. Great call…i see the dental hygienist this Wed.
   / ***UPDATE*** Mice ate my light wiring, ques on the wire connectors #6
I like the others would fix the ones you have. You could also get a new male/female three terminal set at Napa or probably online.
   / ***UPDATE*** Mice ate my light wiring, ques on the wire connectors #7
Welcome to the Mouse Club. I got hit a month ago. It took a while to rewire the mess. They shorted the wiring and battery died. I couldn’t figure out why the battery died. After I charged it, I found all the indicator lights on with the key in my pocket. I then knew it was mice. They have hit me before.
Look at your terminal housing and look for a barb that holds the electrical terminal in place. Picture shows an example.
7E90660B-910F-4E12-B89F-7962E16C7768.jpeg07985085-1090-47E6-B0BA-DADC6B09CB6E.jpeg9A6E187D-5B76-4E50-A583-893189A88C71.jpeg
View attachment 747228View attachment 747229View attachment 747230
Thank you ET & Wrangler / appreciate it
   / ***UPDATE*** Mice ate my light wiring, ques on the wire connectors #9
Harbor Freight has a box of electrical connectors
for about $10
willy
Nissan CF60 6,000lb LP Forklift (A55851)
Nissan CF60...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
9202 (A50322)
9202 (A50322)
2001 Blue Bird Commercial Portable Office Bus (A55852)
2001 Blue Bird...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
