***UPDATE*** Mice ate my light wiring, ques on the wire connectors
   / ***UPDATE*** Mice ate my light wiring, ques on the wire connectors #1
tstex
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
I found out why my lights would not come on (pic 1)
Are the white connectors reusable? (Pic 2&3) If so, what’s the process of removing old and installing new wires?
if not, does anyone have a source?
thank you in advance
   / ***UPDATE*** Mice ate my light wiring, ques on the wire connectors #2
You should be able to release the metal portion (terminal) of fittings (usually have spring lock of sorts that a straight slim object can depress and terminal should come out and you can open up crimps and put on new wires....
   / ***UPDATE*** Mice ate my light wiring, ques on the wire connectors #4
I use dental picks for pushing into those things to release the little spring flats
👍. Great call…i see the dental hygienist this Wed.
   / ***UPDATE*** Mice ate my light wiring, ques on the wire connectors #6
I like the others would fix the ones you have. You could also get a new male/female three terminal set at Napa or probably online.
   / ***UPDATE*** Mice ate my light wiring, ques on the wire connectors #7
Welcome to the Mouse Club. I got hit a month ago. It took a while to rewire the mess. They shorted the wiring and battery died. I couldn’t figure out why the battery died. After I charged it, I found all the indicator lights on with the key in my pocket. I then knew it was mice. They have hit me before.
Look at your terminal housing and look for a barb that holds the electrical terminal in place. Picture shows an example.
7E90660B-910F-4E12-B89F-7962E16C7768.jpeg07985085-1090-47E6-B0BA-DADC6B09CB6E.jpeg9A6E187D-5B76-4E50-A583-893189A88C71.jpeg
View attachment 747228View attachment 747229View attachment 747230
Thank you ET & Wrangler / appreciate it
   / ***UPDATE*** Mice ate my light wiring, ques on the wire connectors #9
Harbor Freight has a box of electrical connectors
for about $10
willy
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2015 Ford E-350 Cutaway Van (A55973)
2015 Ford E-350...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
KUBOTA M7-132 (A53084)
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
