Newbie mini ex questions, and Kubota KX vs U series?
   / Newbie mini ex questions, and Kubota KX vs U series? #21
I don't have that machine but I have 1ft, 18", 24" and 36" buckets for mine. Use the 1ft and the 3ft the most with 24" coming in third. Rarely use the 18"er.
   / Newbie mini ex questions, and Kubota KX vs U series? #22
not sure a ripper will lay pipe, I made a custom bucket for pipe, I can dig a trench 5 inches wide quickly and minimal filling afterwards
   / Newbie mini ex questions, and Kubota KX vs U series? #23
Picture please. I'm working on a 9"(quick coupler width) at the top to 3" at the cutting edge by 38" deep for trenching in the areas the chain trencher doesn't work well.(sticky clay)
   / Newbie mini ex questions, and Kubota KX vs U series? #24
My 12” bucket is just nearly worthless. It stays plugged up. Unless your soil extremely sandy I’d forget about anything smaller.
   / Newbie mini ex questions, and Kubota KX vs U series? #25
Each should have a cool little graph that shows lift in various positions, have a look at those before choosing between the no tail, and tail. Something like below. They are a ton of fun, wish mine was bigger, and had a 6 way blade if that helps.
Best,
ed
   / Newbie mini ex questions, and Kubota KX vs U series? #26
what machine are you putting it on? mine is a Bobcat X change I drew it on cad so it works with there system, no pins, this will dig down 32 inches easily the shallow depth and taper stops it clogging,
If you had to choose just one digging bucket, what size would you choose?
We've clay soils and I'm mainly going to be cutting/filling terraces, digging holes, and generally reshaping our hilly property. It's to go on a 2.5 tonne Kubota excavator.
   / Newbie mini ex questions, and Kubota KX vs U series? #28
for shaping I use a 36 inch tilting bucket, will swivel 35 degrees each way great for ditch work
last week plasma cut the plates so I can mount any attachment in reverse, this allows me to dig against a post or wall with ease, will do a few pictures of this one next week
   / Newbie mini ex questions, and Kubota KX vs U series? #29
24"
   / Newbie mini ex questions, and Kubota KX vs U series? #30
18” or 24”. A 12” is too small to get anything done and a 36 if it’s even available is too big for that machine.
Wacker Neuson G50 38KW (A56857)
Wacker Neuson G50...
PALLET OF MISC PARTS (A58374)
PALLET OF MISC...
Weber CR5 Reversible Plate Compactor (A56857)
Weber CR5...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
2019 John Deere 35G (A55272)
2019 John Deere...
