Ford 1715 hydraulics issue - new owner with dumb questions
   / Ford 1715 hydraulics issue - new owner with dumb questions #1
ssramage
Ford 1715
Forgive me for the basic questions... this is the first tractor I've owned and it's been a LONG time since I operated my granddad's tractor (that was a Ford 1720). My granddad has recently passed and I don't have anyone locally that can help, so I'm asking here.
Either something is going on with my 3pt hydraulics on the rear of my 1715, or it's operator error... When I move the position control lever, nothing happens. Sometimes it'll move slightly, sometimes it'll kind of whine. But most of the time I can move it forward and back and nothing happens. I checked the fluid and it looks clean and full. Filter looks fairly new, but I have not removed it.
Dumb questions...
- Is there a "process" on this tractor that I need to do in order for it to move? For example... RPMs at certain level, brake pedal depressed, PTO on/off?
- I'm assuming it should not matter if an implement is installed or not?
Assuming this is not operator error, where should I start for diagnosis?
   / Ford 1715 hydraulics issue - new owner with dumb questions #2
I think that the position control lever is different than the 3 pt lever that raises and lowers the actual 3 pt hitch.
i do not have a position control lever on my mf1540; just a 3 pt hitch lever.
So.....it is possible that you are using the wrong levers to raise and lower the 3 pt hitch.
I think the position control lever is to maintain whatever level you set the 3 pt hitch at.
   / Ford 1715 hydraulics issue - new owner with dumb questions #3
The position control lever raises and lowers the position of the 3 point hitch. The other lever you speak of is called draft control.
   / Ford 1715 hydraulics issue - new owner with dumb questions #4
Dumb questions...
You may have something going on with the hydraulic pump or it may be just seals in the 3 point hitch piston which is in the case under the seat. Those older fords are usually pretty easy to work on.
Thanks for the replies. I did a full hydraulic service on the tractor and all is working now. (y)
   / Ford 1715 hydraulics issue - new owner with dumb questions #6
Thanks for letting us know and glad you got it all sorted!!
2015 Haulotte 5533A (A53316)
2015 Haulotte...
2004 Saturn VUE SUV (A59231)
2004 Saturn VUE...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
2014 MERCEDES 2500 CARGO VAN (A59904)
2014 MERCEDES 2500...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
2014 RAM 2500 (INOPERABLE) (A58214)
2014 RAM 2500...
