***UPDATE*** Mice ate my light wiring, ques on the wire connectors
   / ***UPDATE*** Mice ate my light wiring, ques on the wire connectors #51
Back in business. Thank you to everyone for your help & experience. I learned about the micro aspects of lighting on 12V battery & tractor.
i also left a bag of moth balls in the hood. The “tomcat” bait that was wired in this time was half eaten. The other/first one was completely removed.
Thanks again guys !!
Best,
tstex
Ok... But what was the solution....
Hello Wrangler.
Since it was mentioned I could reuse the connectors, I figured out how to remove the old male terminals. After removal, I evened up all 6 conductors, removed insulation and crimped them into the new male/uninsulated terminals. Then pushed all the terminals into their respective slots of the connector. I connected the male terminals/connector into the newly fixed ones to test them, and both hi & lo lighting worked fine. (y)
Next, I took doubled sided sticky black electrical tape and wrapped it around the main black flex tube, then to each pair of 3 wires to the terminals, connectors and to the light0heads. I then coated the outside sticky portion w Cayenne Pepper, then wrapped again w the foil tape. "Come and get it!" If they bite into it again, they'll get Cayenne b4 reaching any copper. I also put a bag of mothballs into the area to ward them off. I also left the 1/2 chewed poison block inside the area, which is secured by wire. When I go out this weekend, I am going to check the poison block to see if any more is chewed. I also think these are rats now bc the blk excrement is much larger than a mouse.
I will keep everyone posted of any new issues...thanks again
AIR HOSES & BEAD SETTER (A55745)
AIR HOSES & BEAD...
2018 COMPTANK ACID TRANSPORT TRAILER (A55745)
2018 COMPTANK ACID...
2013 John Deere 35D Mini Excavator (A55973)
2013 John Deere...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
