Oil & Fuel 2003 Jinma 354 Starts runs 1 minute dies and will not restart without fuel prime
   / 2003 Jinma 354 Starts runs 1 minute dies and will not restart without fuel prime
I will take a pic tonight.
   / 2003 Jinma 354 Starts runs 1 minute dies and will not restart without fuel prime #25
All I can tell you is I've use my JM 354 tractor for 21 years. It starts good and runs fine. It was a crate tractor I had to assemble. Besides the usual drain and change all oils and remove and flush fuel tank, I replaced the fuel tank petcock/strainer bowl assembly with a 1/4 npt (had to run a tap in the tank drain for this) and installed a 1/4" npt needle valve. I don't remember from 21 years ago, but, I did some Americanizing of hose and fittings till I got things connected and had good flow to the fuel filter. The OEM petcock had very small orifice and very restrictive for the fuel to come out. So, I understand your issues well and I addressed that right from the get go. bjr
   / 2003 Jinma 354 Starts runs 1 minute dies and will not restart without fuel prime #26
Check your banjo bolts..
The one under the hand primer might have a screen in it..
The one on the inj. pump at the rear(return) should be a pressurized bolt or have an orifice..
It looks as though the banjo bolt next to the hand primer is your pressurizing bolt..& needs to go in the return line..
Simply going by a picture tho.
   / 2003 Jinma 354 Starts runs 1 minute dies and will not restart without fuel prime #27
Well, you don't have a removable side cover, which makes it impossible to see the rack and plunger. Apparently you don't have flow issues because #2 and #3 are firing correctly. Let us know what you find if you remove the #1 barrel & plunger assembly.
thank you....will get into it soon and report back
I am officially done investing anymore time with this......
Does anyone know someone in the Rhode Island Connecticuit or Massachuesettes area that works on
These machines thanx!!
   / 2003 Jinma 354 Starts runs 1 minute dies and will not restart without fuel prime #30
Any journeyman tractor mechanic/dealer that's worth their salt can work on it. It's just a diesel engine.
1987 EZGO Golf Electric Cart (A53424)
1987 EZGO Golf...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
UNUSED FUTURE HYD AUGER (A54757)
UNUSED FUTURE HYD...
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
2008 JCB 520-40 TELESCOPIC FORKLIFT (A51406)
2008 JCB 520-40...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
