Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #20,461
Jspssg, did you ever have an issue with the offset pto angle on your uniforest?
Not yet. The only problem that I did have was when the rod to hold the shaft when it's off the tractor worked it's way out, so when I lifted the winch things bound up and made some not-funny noises. THat was 3 years ago and things still work, but it could have had expensive repercussions.
   / Tractors and wood! Show your pics #20,462
The drive shaft? You normally shut the pto down when lifting the winch to move?
   / Tractors and wood! Show your pics #20,463
Yes.
It's gone now, but the winch had a handy little rod which swung out to rest the drive shaft on when it wasn't attached to the tractor.
I didn't notice that it had moved out, so when I lifted the winch it caught on the rod.
   / Tractors and wood! Show your pics #20,464
   / Tractors and wood! Show your pics #20,465
Has anyone tore out the mounting points of the top link using the three point winches?
   / Tractors and wood! Show your pics #20,466
I believe that retired member Oldpath partially cracked the housing using his winch, before making a reinforcement bracket. He seemed to work that little tractor way beyond it's limits though.
   / Tractors and wood! Show your pics #20,467
Like any tool, I suppose it can be abused. If you size the winch appropriately for your tractor, use the lower pulley on hard pulls (if your winch has one), make sure the blade on the base of the winch is planted on the ground and use some common sense, you won't have a problem.
The most common damage I've heard of from logging winch use is bending the lower three point arms sideways by pulling at too much of a side angle. That is easily avoided: either re-aim the tractor, or use a snatch block to redirect the pull.
   / Tractors and wood! Show your pics #20,468
Speaking of Oldpath, is he no longer around? I could not find him in the member directory, nor could I find old posts by searching for that member name.
   / Tractors and wood! Show your pics #20,469
Interesting. He dropped out after receiving a note from management asking him to remove a religious line from his signature, but until your post I didn't realize that his profile was gone.
   / Tractors and wood! Show your pics #20,470
Remove a religious line from a signature? Guess I need to read the rules.
UNUSED RAYTREE RTSG30 TRANSVERSE STUMP GRINDER (A54757)
UNUSED RAYTREE...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
RoadTec RX500 Screener (A53421)
RoadTec RX500...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
Brock 5 Ton Feed/Grain Tank (A55218)
Brock 5 Ton...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55301)
GALAXY - SET OF...
