FROGSTEPHEN
TWP STAIN / Also full line of cleaners etc & bug juice to add to stain to repel ants etc..
			I use TWP on decking and wood fencing. I switched back to 100 as I found it lasted longer than the environmental (more expensive 200) Some States still allow 100, but I'm not sure about Canada .....I have used Cabot acrylic on my barn siding and it has held up well also.TWP STAIN / Also full line of cleaners etc & bug juice to add to stain to repel ants etc..
The best solution to your problem is use decking until you need replacing. Use Lowes or Home Depot "Trex style" flooring to replace. Material will cost you but it's something you can do yourself saving on labor. No staining, No splinters, and non-slippery when wet. It will be there will no maintenance until floor joist rot out.I'm looking for a quality wood stain/preservative thas is oil based with UV protection that will last. Seems most manufacturers are swticting to water based which I don't like. What are you using? Whats still out there that is oil based?
I never said it was decking.The best solution to your problem is use decking until you need replacing. Use Lowes or Home Depot "Trex style" flooring to replace. Material will cost you but it's something you can do yourself saving on labor. No staining, No splinters, and non-slippery when wet. It will be there will no maintenance until floor joist rot out.
Upkeep needed only when you spill anything that will stain it. Light, very light pressure washing will take care of that.
Built a 12ft X 24 ft porch about 10 years ago. Needed one more board to complete steps. Found one buried, that had been used as a border for a flower bed about 6 years. Dug it up, power washed red mud off, sawed for finishing steps. Looked like new.
One of my best life decisions on any flooring that will be exposed to exterior enviroment.
I used the spar varnish from Helmsman which was oil based and it lasted a few years outdoors but wasn't has long as I hoped. Not sure I'll use that prodecut again.I've not read through, but since I just got in and cleaned up from sanding down a "failed in a year" outdoor patio door (and ain't done yet) urethane job, here's my nickle.
STAY AWAY from Minwax "Pro Series Spar Urethane Indoor/Outdoor". I used it on my deck hand rails and wood framed patio door that are in direct sunlight most of the day. Failed totally in a single season.
It seems fine for indoor use, even in sun, but outdoors, disaster. It is a PITA to redo properly, requiring complete removal down to at least bare wood as any trace of it will show though any "clear" coating you put on. Well, maybe not "any", but I used the "oil based" version from Minwax, thinking it should be more "compatible", but any trace of the water based coating showed through unpleasantly.
The "Helmsman" oil based product seems to last, but does darken the wood a lot more.
We have had great luck with Sikkens Cetol. Use it on a couple of Amish style sheds made from rough sawed pine. Keeps it from turning black. Not cheap but it works well for us.I'm looking for a quality wood stain/preservative thas is oil based with UV protection that will last. Seems most manufacturers are swticting to water based which I don't like. What are you using? Whats still out there that is oil based?
