1972 john deere 820 open center
   / 1972 john deere 820 open center #21
jww1960
When you refer to a line blocking access to hyd filter only line that comes to mind is a brake line. Is that the line you're referring to?
jww1960
must be, its shown going around the filter housing in one of the 3 pics someone sent me in this thread..
but mine is directly across the bottom without zny way to remove filter housing..
and yes there is a dipstick in the rear of the right footrest. not having a manual i thought it was either a foot dimmer switch or sc differential lock..some pb blaster later yep its the dipstick..as for the small line you are saying is a brake line. with all hydro drained im guessing its ok to remove the line to pull filter?
   / 1972 john deere 820 open center #25
Brake line can be R&R'd without draining trans case. You will loose only the oil that was contained in disconnected brake line. One will need to bleed brake after it's been R&R'd
thx sir for all your help
   / 1972 john deere 820 open center #27
You're very welcome. I'm glad I could help you.
   / 1972 john deere 820 open center #28
I somehow kinked that same brake line on my JD 2030. Probably snagged or hit something.
I ordered a new line from JD. It came prebent with flare nuts installed. Fit perfect.
thanks to all, i really enjoy this group,
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A50322)
2019 John Deere...
2011 Chevrolet Equinox SUV (A50324)
2011 Chevrolet...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2018 Kinze 3500 Planter (A52349)
2018 Kinze 3500...
2008 Genie S-65 65ft Telescoping Boom Lift (A50322)
2008 Genie S-65...
2018 Nissan Murano SUV (A50324)
2018 Nissan Murano...
