weld shop clean out job and other Keweenaw sites
   / weld shop clean out job and other Keweenaw sites #71
The company I worked for had a torch head for the plasma, never used it. I think it would have cut the thicker steel better. But then again ours wasn't a large machine. What makes this special to you?
   / weld shop clean out job and other Keweenaw sites #72
Name?
   / weld shop clean out job and other Keweenaw sites #74
:unsure: With your screen name, I figured you for either an "Aronson", or an "Aaron", so a lucky guess on my part.
A good used welder for your garage? There are many more still in here than what I got pics of.
   / weld shop clean out job and other Keweenaw sites #76
I'm going to venture a guess here and bet that there isn't anything that isn't 3 phase in the whole building. I'm actually surprised that the table full of clamps didn't get liberated along the way sometime.
   / weld shop clean out job and other Keweenaw sites #77
So, I'm curious about something, you keep posting the pictures but are you selling any of it or just posting pictures and nothing else. Are you the authorized representative of the liquidation or just a nosey bystander?
   / weld shop clean out job and other Keweenaw sites #78
Fine with me actually, my entire shop is 3 phase with 440 coming in reduced to 220/3 at the drop pole.
   / weld shop clean out job and other Keweenaw sites #79
If you read the whole thread you’ll know that he is working for the guy that owns the property, this was a company that built parts for two other companies that built Tele-handlers.
I could think of a lot less confrontational term than “nosey bystander“.
   / weld shop clean out job and other Keweenaw sites #80
What do you suggest then? Not meant to be confrontational at all, just want to know the bottom line.
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2014 Landoll VT-Plus (A52349)
2014 Landoll...
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A52748)
2009 Ford F-650 24...
Polaris Side by Side (A50324)
Polaris Side by...
ROCK PICKER (A52472)
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
