3 point hitch slow to raise
   / 3 point hitch slow to raise #1
LLIHKAO
cobden
1953 Ford Jubilee
The 3 point hitch on my Ford Jubilee is slow to raise. After I start the tractor, I raise the quadrant lever and sometimes it takes a while for the 3 point hitch to raise; sometimes I have to lower and raise the lever 3-4 times before it will begin to raise at which time it raises slow. When I pull the the throttle back, it will sometimes raise a bit faster. When I shut the tractor off, the hitch lowers itself to the ground. It has done this since 1995 when I purchased it. What should I look for, any ideas on how I can make it work faster? Thanks.
   / 3 point hitch slow to raise #2
Have you checked and or replaced the hydraulic fluid?
yes, i did. i put new fluid in it and checked the levels. all seem to be fine.
   / 3 point hitch slow to raise #4
There should be a draft/possition controll lever under the seat. Move that lever and see if things change.
   / 3 point hitch slow to raise #5
How about the filters or strainer? Did you replace or clean them? Tractor is an antique, the filters / strainers are most likely clogged.
Where are the filters and strainers for the hydraulic system located?
   / 3 point hitch slow to raise #8
Maybe someone will come along that knows. I don't do old tractors but I do know that every tractor ever made will have them.
   / 3 point hitch slow to raise #9
Have a look at this. There are three separate systems it seems.
   / 3 point hitch slow to raise #10
Beyond my previous post you may have to check the hydraulic pump and or remove the rock shaft case to try and further diagnose. Unfortunately it's been a very long time since I have had one of these tractors in my life. I was fairly young and it was my father's. So I don't remember a lot of details about it.
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55301)
Koyker Loader...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2019 Chevrolet Cruze Sedan (A55758)
2019 Chevrolet...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A53421)
2025 GIYI GY-BK56M...
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
2018 Ford Transit 350HD Handicapped Van (A55788)
2018 Ford Transit...
