GM lifter failures-Class action lawsuit for V8's with AFM 5.3L, 6.0L, 6.2L
   / GM lifter failures-Class action lawsuit for V8's with AFM 5.3L, 6.0L, 6.2L #11
mine failed at 120k. its not a small % that fail and those of us that need to pass emissions inspections cant delete it.
   / GM lifter failures-Class action lawsuit for V8's with AFM 5.3L, 6.0L, 6.2L #12
Wonder what Vee-Dub did with all those diesel turn in's they had to buy back? I recollect seeing acres of them parked in holding lots.
   / GM lifter failures-Class action lawsuit for V8's with AFM 5.3L, 6.0L, 6.2L #13
Well, you can or at least the Range delete I have can. You just unplug it from the OBD port and the ECM reverts to it's programmed emission parameters. I don't have that issue here, no tailpipe sniffers out here. My opinion of all the emissions testing is, it's a racket anyway.
   / GM lifter failures-Class action lawsuit for V8's with AFM 5.3L, 6.0L, 6.2L #14
.....and the Range does not reprogram your ecm or leave evidence of you using it.
   / GM lifter failures-Class action lawsuit for V8's with AFM 5.3L, 6.0L, 6.2L #15
and your lifters can still fail in a few different ways, or you can end up with oil pressure issues because of the VLOM.
should have specified, when I rebuilt mine I could not do a physical delete, which is the best way to avoid any issues. i traded it in on a station wagon, and picking up a big block suburban for a truck, it will last way longer than the crap GM is building since 07.
   / GM lifter failures-Class action lawsuit for V8's with AFM 5.3L, 6.0L, 6.2L #16
This issue was one of the major reasons why I bought our 2012 suburban 2500. The 6.0l in these dosnt have the AFM and none of the issues caused by it.
   / GM lifter failures-Class action lawsuit for V8's with AFM 5.3L, 6.0L, 6.2L #17
I just picked up an 01 8.1L suburban and LOVE it. 200k miles and runs and drives great. cheap too, and will pull 12k lbs.
2011 Liebherr L586 Wheel Loader (A55218)
2011 Liebherr L586...
12' CONTAINER (A57193)
BUNDLE OF 8" GALVANIZED PIPE (A57192)
BUNDLE OF 8"...
Sellick S60 (A53317)
2016 Freightliner M2 106 4x4 Altec Bucket Truck (A55852)
2016 Freightliner...
UNUSED FUTURE FT36C STAND ON SKID STEER (A57192)
UNUSED FUTURE...
