Deere 5500 Clutch Adjustment / Service Manual
   / Deere 5500 Clutch Adjustment / Service Manual #1
adc8693
Lexington KY
JD 5500
Does anyone have a link for a service manual for a JD 5500? I used to be about to find one free to view with a simple google search. Cannot see to find one now.
Or can anyone tell me how to adjust the clutch? is it just a pedal adjustment? Seems it is occasionally slipping now when letting off the pedal under load. (I know I overheated heated the clutch trying to get my other tractor out of a bad spot, so I know it took some wear)
Thanks for the help.
   / Deere 5500 Clutch Adjustment / Service Manual #2
Clutch adjustment depends on which transmission you have.
Collar shift and TSS (same procedure to adjust) OR Reverser different procedure to adjust).
Post your transmission type.
It's the 9 speed synchronized. No reverser. I'm guessing I just shorten the linkage?
   / Deere 5500 Clutch Adjustment / Service Manual #4
Is there a clutch adjustment point on a 5500 john deere tractor transmission
   / Deere 5500 Clutch Adjustment / Service Manual #8
   / Deere 5500 Clutch Adjustment / Service Manual #9
Does anyone know how to adjust a clutch in a5500 john deere I think there is a little plate to take of and there is a screw which way to go so hopefully the clutch doesn't slip
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
CFG Industrail MX15RX (A53317)
CFG Industrail...
KBH Tank Trailer (A56438)
KBH Tank Trailer...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
SHOP TOOLS (A58214)
SHOP TOOLS (A58214)
207269 (A52708)
207269 (A52708)
