Deere 5500 Clutch Adjustment / Service Manual
   / Deere 5500 Clutch Adjustment / Service Manual #1
adc8693
Lexington KY
JD 5500
Does anyone have a link for a service manual for a JD 5500? I used to be about to find one free to view with a simple google search. Cannot see to find one now.
Or can anyone tell me how to adjust the clutch? is it just a pedal adjustment? Seems it is occasionally slipping now when letting off the pedal under load. (I know I overheated heated the clutch trying to get my other tractor out of a bad spot, so I know it took some wear)
Thanks for the help.
   / Deere 5500 Clutch Adjustment / Service Manual #2
Clutch adjustment depends on which transmission you have.
Collar shift and TSS (same procedure to adjust) OR Reverser different procedure to adjust).
Post your transmission type.
It's the 9 speed synchronized. No reverser. I'm guessing I just shorten the linkage?
   / Deere 5500 Clutch Adjustment / Service Manual #4
Is there a clutch adjustment point on a 5500 john deere tractor transmission
   / Deere 5500 Clutch Adjustment / Service Manual #8
   / Deere 5500 Clutch Adjustment / Service Manual #9
Does anyone know how to adjust a clutch in a5500 john deere I think there is a little plate to take of and there is a screw which way to go so hopefully the clutch doesn't slip
6ft Wolverine Sweeper (A57454)
6ft Wolverine...
2019 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A60460)
2019 Ford F-550...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
1994 JAGUAR XJ-SERIES (A58214)
1994 JAGUAR...
