Sawmills, sawmill buildings, drying sheds, and kilns... show your pictures!
   / Sawmills, sawmill buildings, drying sheds, and kilns... show your pictures! #281
Mill is up and running!
And I performed my first acts of wood-butchery:
   / Sawmills, sawmill buildings, drying sheds, and kilns... show your pictures! #282
Yippee!!!
hugs, Brandi
   / Sawmills, sawmill buildings, drying sheds, and kilns... show your pictures! #283
Save that for a Bobcat stretcher board.
   / Sawmills, sawmill buildings, drying sheds, and kilns... show your pictures! #284
There are bobcats in our area, but very few and far between.
more likely to cull Coyote than ‘cat!
I am going to take one of those boards and make a sign for the mill shed — “The Wood Butcher Shop” or “Wood Butchered Here” or somesuch . . .
   / Sawmills, sawmill buildings, drying sheds, and kilns... show your pictures! #285
Today was a good day for making stickers!
Today was a good day to do anything here... even for work, which is what I had to do.
Then again, everything seems better on a Friday!!!
Tonight I put a new blade on my mill, tomorrow I will finish sawing what I need before breaking the mill down so that I can move it to a better spot.
   / Sawmills, sawmill buildings, drying sheds, and kilns... show your pictures! #287
I make stickers from 4 foot logs. I manually turn them as that short a log, the log turning claw would just push one end up. I like sawing them this way as I can just cut 1bys and slide them back 4 feet to stack, then I turn the log.
I find it way easier than trying to cut 12-16 foot stickers down with a chainsaw.
I guess it helps to have 20 foot logs in the pile, bucking down to two 8 footers and one 4 footer for the stickers.
hugs, Brandi
   / Sawmills, sawmill buildings, drying sheds, and kilns... show your pictures! #288
"Generally" I also make my stickers out of "shorts", there's always some short "top logs" in a tree, and that's what I aim for.
BUT, if I have a longer "low grade" log, at times I'll use one of those for stickers too.
SR
   / Sawmills, sawmill buildings, drying sheds, and kilns... show your pictures! #289
hugs, Brandi
I am still waiting for my bed extension (on back order… since August. . .) so 13’ is the absolute max i can mill yet. I am still fine-tuning and learning, so stickers are good practice right now.
and I still have to make a landing zone for boards to dry, I will probably start with a couple pallets nailed into a platform, and cover the stack with roof tin for now.
This coming week, I will need to drop a couple more trees and drag them over to the mill.
   / Sawmills, sawmill buildings, drying sheds, and kilns... show your pictures! #290
SR
at this moment, the only short logs I have are walnut, and that is no good for stickers (staining). Stickers are good practice for me at the moment, and I am using top growth logs for this.
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53473)
2016 KBH...
2014 Caterpillar 289D High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2014 Caterpillar...
2008 Ford E-350 18ft Cutaway Box Truck (A51692)
2008 Ford E-350...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
