hunt4570
Super Member
- Joined
- Feb 10, 2015
- Messages
- 5,986
- Location
- South Carolina
- Tractor
- Grand L3540 ,724 loader, bucket, grapple and now forks also! And just for OP.. a pool!
I preferred to move south of the snow belt so I dont care anymore.
Are you going to be driving on asphalt, concrete, gravel, in the woods??What chains do you prefer? It would be primarily for snow plowing etc. But I could use them if I ever get the chance to use the winch in summer as well.
No asphalt. Gravel, ice, sometimes little woods path maybe.Are you going to be driving on asphalt, concrete, gravel, in the woods??
They look alright. What would I be looking at when paying for a similar set?This type is what I prefer with Ag tires plowing gravel and in the woods.
These are made by OFA. Fronts are OFA ECO 8's and the rears are ECO 9's. Better priced than others but still not cheap.
gg
I have OFA EKO 8 chains on the rear tires of my NH TC33D (Which would be the same as what is on your Mahindra 2816, if you have R4 tires on your tractor). They cost me $515 for the pair, but that was back in 2017. I'm sure they are significantly higher than that now.They look alright. What would I be looking at when paying for a similar set?
Ouch. Canadian dollar I’ll be looking at $1000 then. I do need them there however. Always something. I’ll look them up. Tire chain.com
VV,
Chains are the best but I remember what a PITA they were to put on my Ranger SxS. I am 72 and cannot imagine wrestling with them on a tractor tire as I get older. I am looking at adding studs to my LS. I do not work on paved surfaces so studs may be OK.
I'm 43 and dread putting my chains on. I gotta have em, so I do, but dammit they're heavy.
1) lay the chains out with the outside, the ground contact side facing up
2) tie a short cord to the side chains, the length will depend on your tire size, on mine I end up with a V shape about 3 feet.
3) back up to your chain, take the cord and hang it on the tire treads.
4) drive forward slowly, stopping to spread the chain out on your tire.
5) continue doing this till you have rolled the chain up on the tire and have working room at the rear of the tire
6) your chain should be well centered on your tire and have very little slack.
7) fasten your chains.
8) step back and check out your work
I started using that method when I got my Trygg chains for the rears on the L6060 and it was / is an absolute game changer. I no longer agonize about putting those heavy chains on the tractor. It's almost a pleasure ....... almost.If you have not already seen it, you really should try the chain mounting method described by @LouNY in this thread: Mounting tire chains
From Lou's first post in that thread (his thread includes pictures and a pretty good discussion, so it's worth checking out):
I use a slightly different method than what he describes in the first post:
When installing with this method, I rarely have to go back and tighten up my chains after driving on them for a bit. They just wrap right on the tire fairly tightly. (It helps that my OFA EKO 8 chains recommend leaving a little slack - NOT running them tight, an dthey don;t recommend chain sensioners. However, I had the same experience when installing my ladder and Duo Grip style chains: this method really minimized the need to go back and fiddle with chains after the initial installation.
- rather than looping the string/rope over the tire tread, I pass one end through a hole in the rim and then tie the ends to the chain. (My R4 tread is rather worn, so the rope sometimes fell off if I just hooked over the tread)
- Rather than tie on to the side chains, I tie one end about 1/3 of the way along the the cross chain, and the other end 2/3 of the way across. This leaves my side chains free to make the connections before I untie the rope.
________________
Other tips:
The "Euro-style" chains (OFA EKO, Aqualine Talon, etc) fasten in four places, not just at the side chains (as ladder and Duo Grip Chains do). Fasten the inner connectors first before fastening the side chains.
Lay out your chains so the ends with the connectors get pulled over the tire first. I'm not sure exactly why, but I always seem to have an easier time connecting things than if I start with the other end of the chain. (This also matches the installation instructions that came with my chain.)
I've also attached the instructions that came with my OFA chains.
Mr. John_Mc said it the best. I love the EKO's, plus Mr. LouNY's install method.
I'm watching the weather to see when I need to mount them again for this winter and looking forward to giving Mr. John's modified method a try!View attachment 772498View attachment 772499
And when I was younger I liked the snow, and used to go winter camping quite a bit, a new set of challenges to camping.I look forward to the snow each year. Everything is bright and cheery plus the outdoor scenery is beautiful. It's also nicer to watch snow falling instead of rain plus my driveway is a nice white color instead of turning to mud and spraying all over the truck. I will take the snow over rain but I have to admit that some years I can't wait for the snow to go away so that I can go camping and fishing.
ain't that amazing how some lose (probably most) "the kid" in themselves in regards to snow. How it once delighted us and how it's turned to drudgery.And when I was younger I liked the snow, and used to go winter camping quite a bit, a new set of challenges to camping.
