two_bit_score
Super Star Member
- Joined
- Dec 22, 2008
- Messages
- 12,410
- Tractor
- John Deere 110 TLB, Diamond C 19LPX GN trailer
Sorry to hear that @Hay Dude. Hope it can be resolved quickly.
Got it running. Water in fuel separator and batteries that may have been allowed to freeze by previous customer.Sorry to hear that @Hay Dude. Hope it can be resolved quickly.
You're thinking 'Cheques in the mail" scenario?Claims they are Air Flo and those are AR450 steel. Says the serial # tag and manufacturers tag is missing on both bodies…..
It's hard to describe without actually hearing it but 450 has a different, higher pitched ring to it more than regular mild steel if you hit with a bfh. If it hasn't been blasted, the mill scale is a lot less flakier also. Can you get a gander at a spot that hasn't been painted?
So it's got fixed sides with a center chain, odd setup....wonder how the chain feeds all the product unless the sides are sloped to the center? Looks like a well built tailgate, well reinforced and it's also got the high sides you were after. Should handle rocks well as long as the bottom is well built where it'd be cut out for the conveyor.Also don’t want china drive system in floor, but that’s easy to cover.
Maybe a lean on them from the previous owner who still owes money?Just can’t get past the serial tags missing…
Good points…So it's got fixed sides with a center chain, odd setup....wonder how the chain feeds all the product unless the sides are sloped to the center? Looks like a well built tailgate, well reinforced and it's also got the high sides you were after. Should handle rocks well as long as the bottom is well built where it'd be cut out for the conveyor.
That's a really good price. Couple of $K for a dump cylinder, cradle and such and you're in business.I‘ll look around at other truck bodies while I am blasting & painting frame. Time is on my side, for a little while. Might come back to this 12 foot Air Flo. At $5,000 its a very good value
