looking for rare metric bolts
   / looking for rare metric bolts #31
belmetric may work! For some reason they did not come up in my search.
LS parts may work, half of the factory bolts where I did not plate are longer so I may be able to order 16 of them. Thanks everyone for your input, I will give update when I know more.
Isn't Belmetric the $45/bolt place?
   / looking for rare metric bolts #32
Is it possible to use allthread cut to size and nuts for your application ?
Web Parts Catalog.
See where the factory frame goes from double to single - that is where it cracked and the single plate I doubled to match the front. So I should be able to get 16 of those id #10.
Thanks everyone!
   / looking for rare metric bolts #34
Web Parts Catalog.
Thanks everyone!
You may want to triple check your bolt thread pitch.
I checked the parts catalog and they list M14x1.5 which it a lot easier to find. M14x1.25 is pretty much an odd size and most likely a specialty thread of some sorts.
   / looking for rare metric bolts #37
M14 x 1.25 is very close to 9/16-18. It is about .011" smaller and the pitch is about .006" finer. You could probably get away with tapping 9/16-18. In fact, are you sure that's not what it is? An M14 x 1.25 bolt might thread into a 9/16-18 hole just because it is smaller. If it was my tractor I would be tempted.
Eric
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
CATERPILLAR CS563 ROLLER (A52707)
CATERPILLAR CS563...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2021 Kubota SVL75-2 Track Loader (A55314)
2021 Kubota...
KSI Conveyor (A55301)
JOHN DEERE BA84 WORKSITE PRO ANGLE BROOM (A54757)
JOHN DEERE BA84...
