Car battery. I am confused
   / Car battery. I am confused #21
Ahhh, where is the excitment in replacing a battery that isn't stone cold dead? Have some fun, excitment, think the Seinfeld episode when Krammer was test driving a car and wanted to see how far he and the salesman could go with the tank past "E".
   / Car battery. I am confused #22
An old school load tester is definitely viable, I have two of them.
But the impedance tester that I linked to is far better for testing a battery, isn’t as dependent on state of charge and is much cheaper. So for someone without any way to test a battery, it definitely would be my suggestion.
   / Car battery. I am confused #23
I always enjoy looking at pictures shot in a shop. You see the darnedest things...... Popgadget, how many used mower blades do you have there? ;) ;)
   / Car battery. I am confused #24
That Sun is one old piece. I remember using the old Sun that rolled from a steel beam in the shop, timing, points, rpm, emmisions, coils, plugs etc. Boy, things have changed.
   / Car battery. I am confused #25
There’s a couple of sets for the Progressive TD65 at 9 per set as well as a few sets for the Lazer Z. So about 24.
   / Car battery. I am confused #26
Yes, I have had it for probably close to 50 years, but as it’s a carbon pile load, it works as good as the day I got it, just doesn’t get used as often!
As I typed out the initial post, I knew I needed to replace. sometimes forming the thought into a question tells you what the answer is. But I wanted to get some information on how to test, etc. Guess I need to get a load testor for the future shop.
New battery is procured. Napa. I usually get their legend premium but they didn't have one so I got the AAA battery . never seen those before but the guy said it is 3 year warranty and made by Delco. I'll put it in this week. While all the arguments for getting a new one were good, Roustabout had the best point. "no way I'd let a girl run around with a bad battery". not that my boys were any less valuable, but they were less vulnerable. Same reason I bought her a new car ( it was when I got it for her).
   / Car battery. I am confused #28
Also good idea to replace belts and hoses on your own schedule to avoid unexpected breakdowns.
   / Car battery. I am confused #29
It sounds like the plates have shed enough sulfate to touch the bottom and short them. If you want to tinker a bit, you could always try the epsom salts trick to dissolve the crud.
   / Car battery. I am confused #30
I have an old school Sears auto analyzer that checks point dwell, timing, RPMs, and battery. The only thing I use it for now is testing batteries. It would be useful for someone who works on classic cars. On the battery issue, I have found that the dual batteries in my Dodge/Cummins truck last many more years than a single battery in my gas fueled vehicles.
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A52748)
2023 NEW HOLLAND...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52748)
2016 Ford F550 4x4...
2015 FREIGHTLINER CASCADIA DAYCAB (A52472)
2015 FREIGHTLINER...
2010 Cadillac SRX SUV (A50324)
2010 Cadillac SRX...
