Great fuel container.
   / Great fuel container. #1
Fuddyduddy1952
Super Member
john deere
Thought I'd mention this I just received, a really good price on Amazon but sold by JEGS and made in good old USA! Holds 5.5 gallons, the spout is sold separately (cap is threaded for it. Racing we used a funnel).
Lifted up it has a place in bottom for other hand. I know it's probably not epa compliant but makes gas or Diesel filling fast. With vent closed there are no fumes. $25.99.
   / Great fuel container. #3
Y’all need truck or trailer mounted fuel cells and just get rid of all that gas can nonsense for good.
   / Great fuel container. #4
I don't have two acres. I absolutely sip diesel next to you. One might even say I merely dabble in diesel. 🤣
I've used more diesel in my home than I have in my tractor this winter.
   / Great fuel container. #5
Don't recall the brand....but my local Co-op had those in yellow. (not the Jegs 'brand' but otherwise identical to those)
Spout broke off... so I got a brass one that screwed in AND bought a 2' length of (diesel rated) hose. Now I can rest can on hood (International 1066 so I have to hoist it to platform, then hold in front of me to fill tank on top....VERY awkward)
So I can rest can on top of tractor and lean it over until it starts pouring.
I don't care for the vent.... it could be better placed BUT, I'm NOT going to complain. These are EASY to fill, FAST to empty! I think Co-op was charging $35 per unit (been several years so don't remember)
I now wish I had bought 5-7 instead of three of them.
They are my favorite containers.... they also don't spill like my old ones that are missing the vent cover so it splashes and squirts out the vent hole.
   / Great fuel container. #6
I might add... now that I've used them for a while AND had the screw in nipple break on me.... First, I can only pour one at a time, right?
So, I'd like to get some plugs so I can seal the cap. Keep one cap with a hose on it. NOW, I can put them into my trunk of car without the hose sticking up, needing to be bent over to fit and then putting a kink in it.
If I plugged the caps, then I'd simply move the cap with hose to the next can to empty its contents.
   / Great fuel container. #7
They make little itty bitty ones, too
   / Great fuel container. #8
Sell them at Rural King with no name for $25 as well. Have seen them for as little as $14 on sale. Red, Yellow or White..
   / Great fuel container. #9
Ooooooooooh, made with virgin polyethylene.... that makes them even better!
That's a good deal if spout is included. I paid $10 for spout, but it would be easy to make one.
   / Great fuel container. #14
My safety can, you know, the kind you tend to swear at when using, has had a modification (patent pending) done to it such that I no longer need three hands to fuel up the Bobcat.👌
   / Great fuel container. #15
By "Fuel Cell" You mean a 55 gallon Poly Barrel with pump on it?
That works, or small fuel “cube” with hand crank or electric pump.
Handier than a set of vice grips
   / Great fuel container. #16
   / Great fuel container. #17
I actually have been keeping an eye out for a while now, but the stars haven't quite aligned.
   / Great fuel container. #18
Those VIP cans are great. I put a pvc ball valve in the tube of mine so I could simply shut it off when filled. I have 2 of them, been using them for 6 years.
2785 (A60432)
2785 (A60432)
2012 Freightliner Cascadia (A61306)
2012 Freightliner...
2018 Regal 29OBX 29ft Yacht with 34ft Trailer (A59231)
2018 Regal 29OBX...
2018 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A60429)
2018 CATERPILLAR...
CATERPILLAR 72" HANG-ON WHEEL LOADER FORKS (A60429)
CATERPILLAR 72"...
2015 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2015 FREIGHTLINER...
