Right rear wheel spindle, Toro Groundsmaster 220D
   / Right rear wheel spindle, Toro Groundsmaster 220D #1
jrsavoie
Clifton, Illinois
1975 Ford backhoe/loader 3 cylinder diesel, 2022 Kubota LX2610, 1963 John Deere 4010 diesel wide front, 1996 Toro 223D Groundsmaster, 1998 Toro Groundsmaster 325D 4x4 72" deck cab & snowblower
We Need right rear wheel Spindle for a Toro 220D, Model 30794, serial # 80009,
part number RH SPINDLE WA
Part #: 63-6100.
Does anyone have a line on a parts machine or somewhere I might be able to buy the part?
Our 223D is very similar, but has a different part number for that part.
I'm not sure what the difference is
Thanks.
   / Right rear wheel spindle, Toro Groundsmaster 220D #2
I use a local TORO dealer in Crescent OK.
And this distributor: Professional Turf Products Professional Turf Products Euless, TX (817) 785-1900
Fill out this to find yours: Where to Buy | Toro
I have a couple distributors and a few dealers not far away. I believe the part is discontinued.
A few years ago I had a page for GM parts.
I could search by part number and find dealers with old stock on the shelf. Then just call and order the part.
Does Toro have anything like that?
   / Right rear wheel spindle, Toro Groundsmaster 220D #5
Is the engine in yours a ford 4cyl gas ?
   / Right rear wheel spindle, Toro Groundsmaster 220D #6
You might try here. Used Mower Parts | Adams Small Engine He may at least have a used one but has a lot of NOS parts too. We stopped in about a month ago, inside the 50,000 sq. ft. building it is packed with nice used tractors of many brands, NOS parts of many kinds, good used engines etc. Outside is around 2 acres of "pick & pull" tractors & mowers, chain saws, string trimmers, etc. Seems pretty reasonable on prices too.
His specialty is Wheel Horse & Toro products. If he doesn't have one, he may be able to at least point you in the right direction. Shipping doesn't seem to be a problem. He has a FaceBook page and seems every couple of days shows shipping parts, mower decks etc. to as far as California. Also sells parts on ebay. You never know what he will have, as he also shows on his FB page getting in lawn equipment in daily by the trailer load.
My 220D Groundsmaster has the Mitsubishi L3C 20 hp diesel.
From what I can tell. The diesels have the D at the end of the model number.
   / Right rear wheel spindle, Toro Groundsmaster 220D #8
I know a guy that has 2 with the ford's in them that are his parts mowers. I don't know the models and not sure if he would sell parts.
If you know the parts are the same I well give him a call.
There's no way of knowing the parts are the same without the model number and serial number to check on the Toro parts page to see if the parts have the same number.
The same part on our Toro 223D has a different part number than the 220D.
I haven't dug the 223D out to see what the difference in the parts are.
Thanks for the offer
Somebody recommended a good Toro parts place in Florida - CL Equipment 813-238-0956
He's calling back tomorrow.
Sounds like he has the part.
He's very knowledgeable on the older Toro machines.
   / Right rear wheel spindle, Toro Groundsmaster 220D #11
   / Right rear wheel spindle, Toro Groundsmaster 220D #13
Also try WS Equipment in Litchfield Park AZ. 623 853 6984. He specializes in used groundskeeping equipment and parts.
Preliminary Listing / Full Catalog Coming Soon! (A60462)
Preliminary...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
iDrive TDS-2010H...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
