Need favor from Branson 15 series owners
   / Need favor from Branson 15 series owners #1
2515R Dude
KY
Branson 2515R
Hi guys.
I was posting on the hydraulic forum about my backhoe BH150 problem with my 2022 2515R
On the swing it starts real fast, then slows down, then jumps again slamming the tractor,
I recorder it on idle RPM because on the 2000 it is so violent.
Here is the forum
below are the videos.
Could you guys who has similar tractor with backhoe run a similar test and even better to record how your backhoe is moving.
Branson claims it is OK which IMO they try to shake me off and do not honor the warranty.
If i have a video of correctly running BH, i can have a case.
   / Need favor from Branson 15 series owners #2
That looks like "slop" in the hydraulic cylinder mount/hinge points to me.
You can even see it moving in your video.
   / Need favor from Branson 15 series owners #3
Maybe a flow restrictor would help
No one has a BH?
   / Need favor from Branson 15 series owners #9
@Branson Bob has a backhoe on a 20 series and I know he does have some videos. Unfortunately it still will not be the same as yours. Can you do a video of the cylinder moving full swing? Also one of the boom issue?
I'd expect they would behave similarly
2018 DODGE RAM 3500 HD CREW CAB SERVICE TRK (A50459)
2018 DODGE RAM...
UNUSED RAYTREE QUICK ATTACH LOG SPLITTER (A50460)
UNUSED RAYTREE...
2017 CATERPILLAR 938M WHEEL LOADER (A50458)
2017 CATERPILLAR...
2000 Mack CH612 Wet Kit Day Cab Truck Tractor (A48081)
2000 Mack CH612...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
8ft x 6ft Container with Side Door (A48837)
8ft x 6ft...
