Ford 2000 3 cyl gas fuel line
   / Ford 2000 3 cyl gas fuel line #11
   / Ford 2000 3 cyl gas fuel line #12
I'm changing the fuel line from the sediment bowl to the carberator to a steel line with flared fittings. The fitting on the fuel pump side of the sediment bowl fits the carb and it's already a flared fitting. Just don't run it into the carb too far or it will break out the threaded part of the carb. That's experience talking. I was fortunate enough to know someone with a top part of the carb. I'll post pictures later. This can be done for less than $20 unless you break the carb.
   / Ford 2000 3 cyl gas fuel line #13
O'Reilly's
   / Ford 2000 3 cyl gas fuel line #15
Would it have been better to replace the shut off valve?
willy
   / Ford 2000 3 cyl gas fuel line #16
Why, it wasn't the problem.
   / Ford 2000 3 cyl gas fuel line #17
You will have to bend it yourself, which isnt hard, just be careful not to kink it. If you dont have a bender, bend it in small increments and a larger radius.
I have a 1973 Ford 2000 3 cyl gas tractor that leaks where the fuel line connects to the shut off valve. The fuel line and associated parts are 'not serviced' anymore. Does anyone know where I can get the nut and flange that connect into the valve, or even a complete line? Also, what size is the fuel line? Is it 5/16 inch?
Showbox jiofi.local.html tplinklogin
T.C.
40' CONTAINER (A51248)
UNUSED FUTURE FT1000J SMOOTH DOUBLE DRUM ROLLER (A51247)
UNUSED FUTURE...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
