Steel spacers for filled tires?
   / Steel spacers for filled tires? #1
Comancheria
NH TC33DA 2005
Thinking of getting spacers on my TYM 2515.
Not sure if I should go with just rears or get fronts too.
I have lots of rolling hills here in N Ga.
My
Tires are filled and I’m not
Looking forward to fighting them going on and off.
Be nice to have a go jack for tractor tires.
I was also thinking I could fashion a sling around the wheel with a heavy strap and use my engine hoist to jack it into place when I’m ready to go back on.
Keep in mind I’m new to the tractor life and not an expert by any means at this stuf although I’ve been an auto mechanic for 35 years so I have some mechanical skills.
   / Steel spacers for filled tires? #2
If it makes you feel more comfortable than do it.
I actually found a large go jack at Harbor freight that should do the trick lifting loaded tires.
I emailed Bro-Tek three days ago, no reply yet.
   / Steel spacers for filled tires? #4
I'm not familiar with this tractor, but many medium and large tractors) with a 2 pc wheel have several widths available using different mountain of the dish to the wheel and reversing the dish.
Spacers on the front will not gain any side hill stability.
The loaded tire/wheel is best maneuvered to lean against a close truck bumper or tree ect. They're manageable when kept within 5-10* vertically. Any doubts, find another set of hands. They get heavy real fast beyond 10 degrees off plumb (vertical).👍
Yes Sir….I e got a block wall right nearby to lean a tire upon .
Picked up a large go jack from Harbor Freight to help lift the tire into position .
Yes the wheels are one piece deep dish so flipping them is not possible so spacers would be my only option.
It seems in this stock configuration that the front tires stick out about 3” or more than the rears already so spacers in the rear would give it an even stance at least.
Yeah it would be silly to add front spacers for many reasons.
   / Steel spacers for filled tires? #6
I did this last spring on the MX5200. Used a forklift to remove the tires, just slid the forks under the tire, raised that corner of the machine. Put a jack stand under it and then used the forklift to pull the tire off and away.
Replaced in reverse order... they were loaded and I was very glad I had another set off hands when it came time to balance and scooch the tire back on using a long pry bar. Do not underestimate the tire weight
^^^^ I won’t.
I’ll have a couple Son in laws at the ready.
   / Steel spacers for filled tires? #8
I bought the best I could find. Not cheap but not disappointed either. I used a bolt marker after torquing everything per the spacer instructions and tractor specs. Bro-Tek is worth the wait.
I wish they would email me back.
Been waiting to see if they have what I need.
   / Steel spacers for filled tires? #10
Call him. The number is on the website. I put 3" on the rear and 2" on the front.
   / Steel spacers for filled tires? #11
You could drain the fluid out and than pump it back in after you remount.
   / Steel spacers for filled tires? #12
Good Evening Comancheria,
I have the rear rims on my MF1040 dished out for more stability on hillsides. Just feels that the tractor is more stable with this setup !
I ordered some 3” Bro-Tec’s yesterday.
Dude had them shipped like a minute after I hit send on payment…..lol.
I put the Bro-Tek’s on today.
Very fun job.
Wheels were heavy but I didn’t have too hard a time moving them around.
I just let them rest against the front tires.
When I went back on I just let off the parking brake so I could turn the hub to position and lowered the jack as needed and the wheels just fell right onto the bolt holes like butter.
Yes jack stands were still there.
I had to remove the two studs on each hub by simply double nutting the studs to turn them out.
They used some pretty nasty loc tite so I had to chase the threads and used brake kleen to get it all dry.
Used blue loc tite and did not use the tapered lug nuts against the wheel but used the flat ones with my original lock washers…the kit came with both types.
Torqued to 120 LbFt as per instructions, paint penned every lug nut and the spacer bolts on the inside of the hub flange.
I normally would not writem all this but I’m putting it out there in case anyone has the same tractor and is looking to do this.
I don’t drink beer but I feel I need one after that job…..very rewarding.
Here’s some not so great pics of the finished stance.
The last pic shows one side done and the other stock.
^^^Thanks, yeah it really did.
2005 John Deere 7320 (A60462)
2005 John Deere...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
J and L Cargo Express Shadowmaster Enclosed Trailer (A56438)
J and L Cargo...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
