Shell Rotella T4 SAE 10W-30 ALERT!
   / Shell Rotella T4 SAE 10W-30 ALERT! #1
mscheeer772
Member
I have a JD 4310 with an e-power reverser and was wondering if I can use
the above oil for my engine
   / Shell Rotella T4 SAE 10W-30 ALERT! #2
No problem.
   / Shell Rotella T4 SAE 10W-30 ALERT! #3
I thought that something may be wrong with Rotella…..
click bait sorry
   / Shell Rotella T4 SAE 10W-30 ALERT! #6
Alert…… could use an oil waaay better. T4 is very mediocre 😉
   / Shell Rotella T4 SAE 10W-30 ALERT! #9
No idea where you are located. Look at the manual for viscosity vs operating temp range. 10w30 is for cold weather in most diesels. 15w40 for warmer weather.
Rotella is a good oil. T4, T5, T6. Good stuff, but look at the actual viscosity you need
   / Shell Rotella T4 SAE 10W-30 ALERT! #10
Every 200 Hours-JD 4310 oil/filter maintenance
Changing engine oil. Recommended engine oil type: Plus-50, SAE 15W-40, 10W-30, 5W-40. API Service Category CK-4, CJ-4, CI-4 PLUS, CI-4, CH-4. How much to fill: Engine Oil Capacity - 4.3 L (1.14 gal). After completing the filling procedure, check motor oil level.
Ambient temperature isn’t much of a concern if oil used is a good synthetic. Most of the hd diesel engine manufacturers in the past 5 years have been recommending 10w30…
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
We do NOT accept credit cards as payment. (A50123)
We do NOT accept...
