Shell Rotella T4 SAE 10W-30 ALERT!
   / Shell Rotella T4 SAE 10W-30 ALERT! #1
mscheeer772
Member
I have a JD 4310 with an e-power reverser and was wondering if I can use
the above oil for my engine
   / Shell Rotella T4 SAE 10W-30 ALERT! #2
No problem.
   / Shell Rotella T4 SAE 10W-30 ALERT! #3
I thought that something may be wrong with Rotella…..
click bait sorry
   / Shell Rotella T4 SAE 10W-30 ALERT! #6
Alert…… could use an oil waaay better. T4 is very mediocre 😉
   / Shell Rotella T4 SAE 10W-30 ALERT! #9
No idea where you are located. Look at the manual for viscosity vs operating temp range. 10w30 is for cold weather in most diesels. 15w40 for warmer weather.
Rotella is a good oil. T4, T5, T6. Good stuff, but look at the actual viscosity you need
   / Shell Rotella T4 SAE 10W-30 ALERT! #10
Every 200 Hours-JD 4310 oil/filter maintenance
Changing engine oil. Recommended engine oil type: Plus-50, SAE 15W-40, 10W-30, 5W-40. API Service Category CK-4, CJ-4, CI-4 PLUS, CI-4, CH-4. How much to fill: Engine Oil Capacity - 4.3 L (1.14 gal). After completing the filling procedure, check motor oil level.
Ambient temperature isn’t much of a concern if oil used is a good synthetic. Most of the hd diesel engine manufacturers in the past 5 years have been recommending 10w30…
2009 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2009 MAC MFG 53'...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51691)
2016 Ford F-550...
2012 Audi Q5 AWD SUV (A51694)
2012 Audi Q5 AWD...
2014 Ford F-150 Ext. Cab Pickup Truck (A52377)
2014 Ford F-150...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
