Shell Rotella T4 SAE 10W-30 ALERT!
   / Shell Rotella T4 SAE 10W-30 ALERT! #1
mscheeer772
Member
I have a JD 4310 with an e-power reverser and was wondering if I can use
the above oil for my engine
   / Shell Rotella T4 SAE 10W-30 ALERT! #2
No problem.
   / Shell Rotella T4 SAE 10W-30 ALERT! #3
I thought that something may be wrong with Rotella…..
click bait sorry
   / Shell Rotella T4 SAE 10W-30 ALERT! #6
Alert…… could use an oil waaay better. T4 is very mediocre 😉
   / Shell Rotella T4 SAE 10W-30 ALERT! #9
No idea where you are located. Look at the manual for viscosity vs operating temp range. 10w30 is for cold weather in most diesels. 15w40 for warmer weather.
Rotella is a good oil. T4, T5, T6. Good stuff, but look at the actual viscosity you need
   / Shell Rotella T4 SAE 10W-30 ALERT! #10
Every 200 Hours-JD 4310 oil/filter maintenance
Changing engine oil. Recommended engine oil type: Plus-50, SAE 15W-40, 10W-30, 5W-40. API Service Category CK-4, CJ-4, CI-4 PLUS, CI-4, CH-4. How much to fill: Engine Oil Capacity - 4.3 L (1.14 gal). After completing the filling procedure, check motor oil level.
Ambient temperature isn’t much of a concern if oil used is a good synthetic. Most of the hd diesel engine manufacturers in the past 5 years have been recommending 10w30…
2023 Yamaha Wave Runner Deluxe with S/A Aluminum Trailer (A51694)
2023 Yamaha Wave...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2013 KENWORTH T800 KILL TRUCK (A53843)
2013 KENWORTH T800...
2004 Ferrara Pumper Fire Truck (A51692)
2004 Ferrara...
377811 (A48836)
377811 (A48836)
2019 Ford F-150 XL (A50123)
2019 Ford F-150 XL...
