/ John deere 4300 dies when i let off clutch in foward or reverse but runs fine until going invto gear. Anyone aquire this problem and could help
#1
You may have restricted fuel delivery. You have enough fuel to idle with no load but when you release the clutch, the added load can't be met with enough fuel flow so the engine dies.John deere 4300 stalls dies when letting off clutch in forward and reverse. Runs fine until then. Anyone have this problem that could help.
I would try this before doing anything else. Aside from starting with the easiest things first, it sounds like a safety switch issue.quick test if your seat safety switch is still operational is to disconnect it from the seat and put a paper clip or small wire and jump the two terminals together.
