John deere 4300 dies when i let off clutch in foward or reverse but runs fine until going invto gear. Anyone aquire this problem and could help
   / John deere 4300 dies when i let off clutch in foward or reverse but runs fine until going invto gear. Anyone aquire this problem and could help #1
bofixit
John deere 3400
John deere 4300 stalls dies when letting off clutch in forward and reverse. Runs fine until then. Anyone have this problem that could help.
   / John deere 4300 dies when i let off clutch in foward or reverse but runs fine until going invto gear. Anyone aquire this problem and could help #2
have you looked to see if there is any water in your fuel separator?
   / John deere 4300 dies when i let off clutch in foward or reverse but runs fine until going invto gear. Anyone aquire this problem and could help #3
You have the gear, sync-reverser or hydro trans? A quick test if your seat safety switch is still operational is to disconnect it from the seat and put a paper clip or small wire and jump the two terminals together. The switch is notorious for going out or causing issues especially when weather get colder and the seat cushion starts to stiffen up.
   / John deere 4300 dies when i let off clutch in foward or reverse but runs fine until going invto gear. Anyone aquire this problem and could help #4
Any chance your brakes are stuck on ?
   / John deere 4300 dies when i let off clutch in foward or reverse but runs fine until going invto gear. Anyone aquire this problem and could help #5
Does your clutch have a sensor?? Because its the clutch moving
would think it has something to do with it when it moves to shut
down the engine
willy
   / John deere 4300 dies when i let off clutch in foward or reverse but runs fine until going invto gear. Anyone aquire this problem and could help #6
You may have restricted fuel delivery. You have enough fuel to idle with no load but when you release the clutch, the added load can't be met with enough fuel flow so the engine dies.
Check the fuel delivery.
   / John deere 4300 dies when i let off clutch in foward or reverse but runs fine until going invto gear. Anyone aquire this problem and could help #7
I would try this before doing anything else. Aside from starting with the easiest things first, it sounds like a safety switch issue.
   / John deere 4300 dies when i let off clutch in foward or reverse but runs fine until going invto gear. Anyone aquire this problem and could help #8
no replies from this 1. this could be a dead end thread with no response back. guess we will see.
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A60460)
2019 Caterpillar...
2007 Frienghtliner B2 School Bus (A59230)
2007 Frienghtliner...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
