Tell me about cylinder safety locks
   / Tell me about cylinder safety locks
If I wasn't parallel and between trusses, I too would chain and not worry.
   / Tell me about cylinder safety locks #12
Caution anyone using loader locks to cushion them with rubber to not nick the chrome cylinder rods. OEM lock has a rubber bumper.
   / Tell me about cylinder safety locks #13
I either tie up the bucket on the sealing lift point in the shop or I put stands under the loader lift arms or even better I remove the FEL which is quick connect so it is very quick, these are standard practice in the industry, I have never seen cylinder lock but they should work, like other pointing out as long as it doesn't damage anything.
   / Tell me about cylinder safety locks #14
Simple, heavy strut will do it, but if you are worried about 1, use 2.
Do you apply any pressure/weight at the contact point(s) from the FEL once in place?
   / Tell me about cylinder safety locks #16
Do you apply any pressure from the FEL once in place?
No. Raise the loader (FEL), secure the brace, shut off tractor and lower the loader down on the brace(s). Relieve any line pressure on lift circuit.
Word of caution. At this point of bracing the lift arms, you need to decide whether you want the bucket tilted back and it will stay OR put the bucket in full dump, shut off engine and cycle the bucket circuit to relieve pressure.
IF THE BUCKET EDGE HANGS DOWN LOWER THAN 6'6" +/-, HANG FLAGS OFF OF THE EDGE OR PUT FOAM CUSTIONING ON EDGE!
   / Tell me about cylinder safety locks #17
If you are going to use the cylinder safety locks, definitely use 2. With only one, when you decide to lower the loader while having a brainfart, your loader could look decidedly different than when you started. Ask me how I know.
These are the ones I use on a BX23.
   / Tell me about cylinder safety locks #19
Thanks for the pics, I'll be copying your design Very soon. Are those supports mad of 1/2 sections of pipe? They don't look like angle iron.
   / Tell me about cylinder safety locks #20
Yep, that's exactly what they are and the curved ends are the outside shells of euchered bearings.
2012 BMW 328i Sedan (A53424)
2012 BMW 328i...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2011 Freightliner M2 112 Tri-Axle Dump Truck (A55852)
2011 Freightliner...
2023 Kubota Z252KH-54 Zero Turn Mower (A55314)
2023 Kubota...
