Hydraulic Oil cooler for Kubota L5450DT
   / Hydraulic Oil cooler for Kubota L5450DT #1
fiddlinvet
Kubota L5450
Is anyone parting out an L5450DT/L4350DT /L4850DT?
I urgently need an hydraulic oil cooler for my tractor.
Alternatively: which oil cooler can I adapt for my L5450?
I just cannot afford around $1000 for a new one. I already had the old one repaired, but that repair only lasted for about 2 hrs....
   / Hydraulic Oil cooler for Kubota L5450DT #2
use your imagination call
some used part houses. as long as you can mount it up some how and adapt fittings will work most coolers should not be running more than 300 psi and lot of aftermarket stuff can be adapted
   / Hydraulic Oil cooler for Kubota L5450DT #3
Not sure what sort of room you have up front or what size the hydraulic lines are but wondering if you could find a transmission cooler that might work..?
I have called pretty much every used and new part place on the internet. Not available used and only two places have it new for $930 and over $1400. I am not an experienced tractor mechanic.
   / Hydraulic Oil cooler for Kubota L5450DT #5
Sounds like you've exhausted all avenues for original part which is why I suggested a transmission cooler that is normally used to cool transmissions on vehicles. You might have to get a mechanic and/or fabricator involved to see if it would work. Not sure if it would be cheaper though, would take some calling around. Or buy the new part and be done.
Just trying to help.
   / Hydraulic Oil cooler for Kubota L5450DT #6
😀 $1000 is a joke, find somethimg else that will work like a tranny cooler
Thank you
   / Hydraulic Oil cooler for Kubota L5450DT #8
Give me dimensions I will call
My buddy at agco he has lots of used parts old cooler
Of a industrial tractor might work
Thank you.
I am also adding the pump specs (pump works)
Pump flow13gpm / 49.2lpm-
   / Hydraulic Oil cooler for Kubota L5450DT #10
Thanks will call him Monday
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A51246)
2016 CATERPILLAR...
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
2018 FREIGHTLINER BOOM TRUCK (A51406)
2018 FREIGHTLINER...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
2017 FORD F550 XL SUPER DUTY BUCKET TRUCK (A51406)
2017 FORD F550 XL...
