John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #1
VOL54
Member
NW Tennessee
New Holland TC45DA, John Deere 345
Greetings......I have a John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine.... Engine just clicks when trying to start (will finally start)....ongoing problem for over a year....finally decided to replace the starter solenoid today. I got everything all put back together only to discover it's still doing the clicking thing. It was getting late so I decided to start it and move it out of the way till tomorrow morning only to have it quit before I could get it parked. Will turn over but won't start. Anyone have any suggestions as to where I should start to get it running again? Thanks for your help.
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #2
Deere 345 has several interlocks on both the start and ignition circuits. The service manual does a pretty good job of explaining diagnostic procedure for each circuit.
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #3
Check all your electrical connections, especially around the starter and battery
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #4
"check" meaning removing and cleaning, as sounds like corrosion is possibly causing a disconnect.
Well, it starts now(it was the seat safety switch), but the clicking noise when starting persists. New starter solenoid installed to no avail. Still clicks. Could problem be the starter itself?
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #6
Battery cable connections need removal and cleaning, or battery needs load testing. If that doesn't work, then go after the starter.
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #7
check ground wire.
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #8
fuel filter or water in gas.
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #9
  • Good Post
Reactions: fc1
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #10
he said the motor turns over.
377780 (A48837)
377780 (A48837)
2021 Liebherr L556 (A52128)
2021 Liebherr L556...
E-Z Trail 675 Grain Cart (A50514)
E-Z Trail 675...
2012 Chevrolet Malibu Sedan (A50324)
2012 Chevrolet...
2015 CATERPILLAR AP1055F ASPHALT PAVER (A51242)
2015 CATERPILLAR...
2024 CATERPILLAR 299D3 XE SKID STEER (A51242)
2024 CATERPILLAR...
