Where to best measure hydraulic oil pressure and temperature?
   / Where to best measure hydraulic oil pressure and temperature? #1
MaxG
Queensland, Australia
DongFeng 30HP Tractor, Shandong Noute 2.5t Excavator
I wonder where to best measure hydraulic oil pressure and temperature on a 2.5t digger.
General wisdom says oil temperature is most accurate at oil return.
Where should I measure pressure?
I reckon there are different places, but pressure would only show when the particular cylinder is operated.
So for a more general measurement should I measure at the pump outlet? But then I have a dual pump.
Any hints appreciated.
   / Where to best measure hydraulic oil pressure and temperature? #2
Measuring system pressure is generally AFTER first device that has pressure relief valve in system (a constant), at pump outlet is whatever pump can create as for whatever rpm pump is turning so pressure can fluctuate....
A common practice is to do pressure check at a QC for FEL.... IF your tractor/digger does not have a QC then you probably will have to tap one in at a convenient spot AFTER first systems pressure relief valve ... IF your tractor does not have oil cooler I'm not sure what difference it makes knowing oil temp....
   / Where to best measure hydraulic oil pressure and temperature? #3
How are you going to measure hydraulic oil temperature?
I measure pressure at the input to the FEL controls. It would be better at the main pump outlet. I use theFEL control because it is more convenient. Measuring there gives pressure on loader lifts as well as some backhoe functions. ...plus a baseline pressure that is losses from the fluid circulating through the system.
   / Where to best measure hydraulic oil pressure and temperature? #4
Temperature reading is usually reservoir temp after getting to operating temperature.
This is what is coming out of reservoir and back into the system.
Thanks guys; will see what adaptors I need to hook into the system.
   / Where to best measure hydraulic oil pressure and temperature? #6
My hydraulic temperature gauge is a Amazon thermocouple taped to the hydraulic hose and covered with a wad of insulation. The handheld readout sits in a coffee cup holder when I'm curious, but it usually lives in the toolbox. $29.00 complete.
The pressure gauge is older & permanent. Amazon sells a complete kit with extra types of adapters for under $100... but I didn't need the complexity. Mine is just an appropriately threaded T threaded directly to the control valve input, and supporting a glycerin-filled 1/8" NPT 5000 psi stainless steel 2" gauge. The T is hydraulic spec, not the plumber's type. Cost of the whole setup was uder $30.
Here is the hydraulic temperature gauge I used:
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A57024)
Neckover GL24-2-7K...
Elgin Pelican Street Sweeper (A55851)
Elgin Pelican...
2006 INTERNATIONAL MA025 BOX TRUCK (A56138)
2006 INTERNATIONAL...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
CATERPILLAR HYD HAMMER (A52707)
CATERPILLAR HYD...
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
