Ford 3000 tractor telescoping lift arms
   / Ford 3000 tractor telescoping lift arms #1
steve's3000
1971 Ford 3000
Hello, has anyone replaced there non-teloscoping lift arms with telescoping lift arms on their 3 pt. for a 1971 Ford 3000 tractor. If so what part number or what tractor telescoping lift arms will work. It is really cumbersome to cool up a heavy 3 pt. attachment.
It looks like just maybe the arms off a Kioti ck2610, ck3510 may work. They are also 31" long but not sure of angles at the ends and thickness of the arms. Mine are 1/2" thick. The Kioti may be 3/4" thick.
Thank you
   / Ford 3000 tractor telescoping lift arms #2
I haven’t, but the extendable 3 point arms on my TC45DA are the best thing ever IMHO. 😎
I want to add a set to my IH 424 if I keep it as they make hooking up 3 point equipment a very non-strain full event.
   / Ford 3000 tractor telescoping lift arms #3
Best thing ever until someone came up with a quick hitch. 🤣
   / Ford 3000 tractor telescoping lift arms #5
Or a Pat's easy hitch which is probably easier and cheaper to install
   / Ford 3000 tractor telescoping lift arms #6
Mine was $89 as I recall. What's yours? And I don't have to get off my tractor to attach most implements. Grab and go for everything that doesn't need a PTO connection. Pat's doesn't include the top link. How do you deal with that "quickly"?
How long are they on the TC45DA? How thick are they?
   / Ford 3000 tractor telescoping lift arms #9
They are about 34” overall length, the arms are about 2 3/8” deep (top to bottom) and about 13/16” wide.
   / Ford 3000 tractor telescoping lift arms #10
I haven’t found a source for moderately priced “generic” extendable link arms. When I was considering switching my two tractors with standard arms the best I could find was through the OEM and they were outrageously priced.
I ended up welding euro hooks on. They’re heavier duty than the Pats system, but you will need a welder.
I have another tractor with extendable links and I prefer the hooks, but it’s not so bad that I’m in a hurry to switch that tractor too.
2019 HINO 268 26FT BOX TRUCK (A52141)
2019 HINO 268 26FT...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
J & M 1150 Grain Cart (A50514)
J & M 1150 Grain...
CATERPILLAR 325FL CR EXCAVATOR (A51242)
CATERPILLAR 325FL...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
