Hydraulic oil in eng oil
   / Hydraulic oil in eng oil #1
TC 35D owner
TC35D
TC35D replaced three hoses and a hydraulic cylinder. Checked fluids and refilled as needed. I started working machine and backhoe was digging but with reduced power for a bit. Friend started using backhoe and said he heard “a noise like something break”. I know- not very descriptive but best I could get. Power improved but now dumping hydraulic fluid into oil as evidenced by oil overflow tube blowing out oil/hydraulic mixture and engine oil now showing overfilled and with the same mixture.
So- I have an idea what the problem might be but want educated (cause I’m a novice) opinion and suggested repair.
Thx is in advance.
   / Hydraulic oil in eng oil #2
It sounds like your hydraulic pump is leaking into the crankcase. It is powered directly from the engine and sometimes they leak.
   / Hydraulic oil in eng oil #3
Most likely place for the leak would be hyd pump shaft seal. It is double lipped seal on the pump input shaft.
Thanks. That’s what i was guessing from reading up. Do you know if a replacement seal installation is difficult?
And is it just a coincidence that this blew with an hour of operation after I replaced 3 hyd hoses and a hyd cylinder? Or could the replacements created a problem and tvs seal will blow again?
   / Hydraulic oil in eng oil #6
No. It is pretty easy but you need to be careful and not rough with removal. I have a few pics below FYSA. For just shaft seal replacement you do not need to do pump disassembly but you do need to remove the pump. You need to remove the nut on the shaft while holding on to the gear in a vice sandwiched between couple of pieces of wood to avoid damage to the gear. The shaft seal has a snap ring that seats in an internal groove. Need to use a pick and remove the shaft seal, that will destroy the oil seal completely. Clean the shaft and the groove well. Use a deep socket that fits the dia of the new seal, lube the shaft and seal and slowly but firmly drive the new seal. This is a one time deal.Make sure the seal is nice and square to the shaft. After that put the spring loaded retainer ring and make sure it is fully seated in the groove and then put the pump back.
JC,
   / Hydraulic oil in eng oil #7
My seal also looked good but was not making pressure so ended up doing it after pump overhaul. Gear pump is a positive displacement pump unlike a centrifugal pump. You can not dead head a gear type pump and the seal is path of least resistance. If you have a pressure gauge use it and see what pressure you are developing.
JC,
View attachment 1036575View attachment 1036576
Thanks for taking the time to give me a great explanation and the pics.
Have a great weekend.
   / Hydraulic oil in eng oil #9
You're welcome. You too. Let us know how your repair is progressing and if we can help more.
   / Hydraulic oil in eng oil #10
Usually never just the main shaft seal. The internal seals hold the pressure.
Sounds like the relief valve on the backhoe may be set higher than your pump can handle.
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2015 Cadillac Escalade SUV (A50324)
2015 Cadillac...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2018 CATERPILLAR 336FL EXCAVATOR (A51242)
2018 CATERPILLAR...
