Pictures from a skid steer mowing contractor
   / Pictures from a skid steer mowing contractor
Lineman, I noticed in your last pick that you are using a split tilt trailer. Do you recommend it for a person with a compact tractor and brush hog?
Do you find any limitations with it?
Yes I would, I haul my small tractor with FEL and 6' bush hog on mine and can load it forwards or backwards with no issues, and while I mostly use it to haul my skidsteer with , I haven't had any issues for my uses with anything I haul, I didn't realize what a pain messing with ramps on my old equipment trailer was until I got this tilt deck, I can't ever see myself going back to an equipment trailer with ramps, now if I hauled material strictly I would for sure get a deck over, but I have a gooseneck deckover for hauling hay and my big tractor. The Kaufman tilt deck trailers are dirt cheap because you buy directly from one of their factory's and apparently they sell a lot of them.
   / Pictures from a skid steer mowing contractor #682
Keeping that center of gravity low is good... saw this headed up Blanding Blvd this morning
   / Pictures from a skid steer mowing contractor #683
I should upgrade my trailer. A tilt deck would be nice. Kaufman price not too bad.
I believe you would like it, I upgraded and went with the 8k axles and 17.5 super single tires with a spare for a little over $8000.00 and they were great to do business with.
   / Pictures from a skid steer mowing contractor #686
A guy flew by me on I-20 yesterday with a small excavator on a trailer with just one strap holding it down. I'm not sure what it was doing, it looked like it went over the tracks, just behind the blade, and was attached to each side of the trailer. My guess is that gravity was holding it on there!!!! I was doing 80mph, and he was going a lot faster then that!!!
I bind my skidsteer down with chains and a binder at all 4 corners, only takes a few minutes.
   / Pictures from a skid steer mowing contractor #688
That's how I do it too. It's kind of become a thing to see how other people haul stuff, so I'm always looking when I see something on a trailer.
   / Pictures from a skid steer mowing contractor #690
Isn't that what DOT requires, though not everyone does it..?
Equipment under 10,000 pounds can use the requirements for automobiles, light trucks and Vans. That only requires being restrained at the front and the rear with a minimum of 2 tiedowns. Above 10,000 pounds has to have a minimum of 4 tiedowns, plus any accessory equipment, such as an FEL or implement on the 3 pt hitch has to be secured.
I do it that way on my tractors using chains and binders at the corners, straps for the implements, even though none weigh over 10,000 pounds. Even smaller equipment such as the Mule or ZTRs gets 4 ratchet straps, 1 at each corner.
2013 PETERBILT 367 (A50854)
2013 PETERBILT 367...
2019 BOBCAT S770 SKID STEER (A51242)
2019 BOBCAT S770...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2020 John Deere 6110M 110HP 4WD Agricultural Tractor (A49461)
2020 John Deere...
2014 CATERPILLAR 277D SKID STEER LOADER (A51222)
2014 CATERPILLAR...
2008 CAT 287C (A50854)
